Home > Technical > ABS Modulator
VOD80
France 2003 Defender 110 Td5 CSW Zambezi Silver
ABS Modulator
Hello all,
I'm a bit of a lurker but I've come out of the woodwork with a question - my ABS/TC lights are on permanently. I've checked the sensors and harnesses (as well as I could just by looking!) and they seem OK. The ABS is clearly not working (I can lock the brakes up while stopping) so I suspect the ABS modulator.
This seems to be similar to the Disco II version but there seems to be less information about the Defender version. Does anyone know if the same fix can be applied to the Defender?
This is the Disco II version: www.landroverclubvi.com/abs-mod.html
I need to get the code read first, to be sure but I'm preparing myself!
This is for a 2003 TD5 Defender 110 Station Wagon.
Cheers!
Post #100326 16th Nov 2011 3:26pm
Lorryman100
deleted.
Post #100708 18th Nov 2011 1:19pm
rangehelper
Russia
This improvement is perfect for your car.Only in an extra lot. Upgrade should only Shatll Valve. And it works, checked up.
Post #101049 19th Nov 2011 8:34pm
VOD80
Thanks RangeHelper, I'll let you know how I get on if this is what I need to do (need to get the codes read forst!)
@Lorryman100 - you shouldn't have deleted your post - I thought it was a great checklist for things to verify before leaping into the more expensive stuff. Is there any chance you could post it again?
Thanks,
Tony
Post #101215 20th Nov 2011 8:34pm
DBMG
United Kingdom 1999 Defender 90 Td5 HT Epsom Green
Thanks,
Tony
I have the same fault and would like to have a look at your check list Lorryman100.
Thanks,
Stephen..
Post #103985 2nd Dec 2011 10:06am
rangehelper
Russia
Send me your e-mail. I'll post the file to upgrade the ABS . Modernization held me for three cars successfully.
Post #104805 5th Dec 2011 7:53pm
shazzy90
i also have problem of abs and tc lights on all the time
Post #105450 7th Dec 2011 10:38pm
Lorryman100
DBMG wrote:
Thanks,
Tony
Thanks,
Stephen..
Sorry, I deleted the post as it already had been posted in a similar thread and I didn't see the point in duplicating the post. Thumbs Up
A quick search reveals:
http://www.defender2.net/forum/topic8302.html
http://www.defender2.net/forum/topic7119.html
Post #105452 7th Dec 2011 10:45pm
DBMG
Lorryman100 wrote:
DBMG wrote:
Thanks,
Tony
Thanks,
Stephen..
Thanks. Will read all posts..
Post #108282 18th Dec 2011 10:14pm
