![]() | Home > Puma (Tdci) > Rear Passenger Door Seals |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Had a similar issue with the rear door seal on my 90, bottom left hand side! Removed the seal cleaned off the area, small bead of Sikaflex adhered the seal to the frame and liberally coated the door with silicon based grease to prevent the door from snagging it and pulling it off when closing. No issues since as the seal forms to the correct profile eventually. If you go through life with your head in the sand....all people will see is an ar5e!!
| bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248
Hi Brendan
I don't have a problem with them staying put, front and rear leak like sieves though Try taking the seal off and gently closing the inner edge with a pair of pliers or grips. This should close the u shaped inner metal lip and keep it in place. Good luck Bob |
| Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266
Brendan, all you need is some dum dum (bodycorking)
| G4sweep Member Since: 24 Sep 2010 Location: Paderborn Posts: 182
I have the same issue on the left hand rear passenger door of our 07 USW! although can't imagine it's only these models which suffer this problem!!! we use our rear doors all the time for our nippers and is now becoming a royal PITA! Will give the gum gum a shot or failing that the silkaflex and if they fail some new seals. Cheers for crimbo card too Brendan and Barbara 2.2 110 XS SW ---------------------------- Gone; 08 D3 XS BN55 WPV G4 4.4V8 D3. O7 G4 Mongolian Recce 110 USW |
| RFT Member Since: 13 Nov 2010 Location: Yorkshire Dales Posts: 695
Just had all mine (all 4 doors) replaced by dealer under warranty, let's see how well these last. 130 Puma HCPU with an Artica 240LR Demountable Camper
| All times are GMT |
