Home > Td5 > A couple of questions about our td5...
Gareth
Now we have had the TD5 90 a week, there are couple of things that I need to know.
1. Sometimes we leave the dog in the car for a few minutes. Is it possible to lock and alarm the car, but without the interior sensors active? on my D3 I press the lock button twice to do this. Unfortunately, I need to get some new lock barrels for the doors, as the ignition lock seems to have been changed at some point, so until I have done this, locking with the key is impossible and I have to use the remote.
2. What additional security measures do people use? I am very aware that Defenders are a hot target for thieves. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #108082 17th Dec 2011 6:23pm
K9F
A. 1.....Quick search revealed....
http://www.defender2.net/forum/topic7681.html?highlight=dog
A. 2....Search under alarm/modifications/upgrade... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #108084 17th Dec 2011 6:29pm
alanhid
Scotland 2006 Defender 90 Td5 XS CSW Bonatti Grey
1. Get lock barrel replaced and lock with key. 2. Disklok , best steering lock on the market, as well as being highly visibil. Life is not a rehearsal!
Def 90td5 CSW xs 2006
Post #108153 18th Dec 2011 11:08am
Martin
Site Admin
Gareth - you do know that the ignition key and the door keys are different anyway?
You should have a long key with a black head (column), and a shorter metal-only key (doors).  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #108176 18th Dec 2011 2:50pm
Thor
United Kingdom 2002 Defender 110 Td5 CSW Bonatti Grey
Can't help on the alarm front sorry but having been a victim of car theft (some scum bag broke in and stole the keys for my VW Transporter and work car) I now have the factory fitted alarm, a toad catagory 1 alarm and imobiliser, a disk lock as well as a clutch claw on my TD5
The steering lock and alarms are fitted/activated evrytime I leave the landy.
The keys are now locked in a small safe when they'rein the house.
Horrible feeling to wake up and them not be there, so do everything I can to stop it happening again!
Post #108189 18th Dec 2011 4:43pm
Gareth
Martin, I have two black keys that start the car, 2 alarm fobs that lock unlock it, and 2 metal keys that undo the fuel cap.
The black ignition keys also lock/unlock the rear door. They fit into the door locks but won't turn them. The metal keys only do the filler cap, although they do fit the doors, but feel too small.
Wendy had a bit of an issue this evening when she finished work. She works at Lyme Park, it was very cold up there today. When she tried to get in, the front doors had frozen up and would not unlock at all with the central locking. She said it just locked itself again as soon as she unlocked it. This is when she discovered that the ignition key opened the rear door. 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #108287 18th Dec 2011 10:58pm
JWL
The door locks may well be for the keys you have, it may that they've never been used, previous owners just relied on the remote and never put the key in the lock and the barrel is siezed from lack of use.
Post #108291 18th Dec 2011 11:15pm
Gareth
That is possible, they do feel like there is no movement whatsoever. I guess I will strip the door card off and have a look at the locks. I have searched and found that replacement barrels and keys are not expensive. 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #108294 18th Dec 2011 11:18pm
Bobble
Re: A couple of questions about our td5...
Thumbs Up
Post #108296 18th Dec 2011 11:22pm
kzycnn
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Gareth, that's right for a post '02 model year TD5. Also, just locking with a key should leave the interior sensors inactive. Using the remote sets everything.
Tony
Post #108335 19th Dec 2011 9:01am
Gareth
So, is the fuel cap key supposed to do the doors as well?
The pictures I have found for replacements look like the fuel cap key.
Post #108339 19th Dec 2011 9:16am
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
I have exactly this problem with my Td5 (55 plate). I can work the ignition and the rear door with one key, but have no others. The key will fit in the driver's door but will not turn. I assumed it was supposed to and that the barrel had seized?
My old Td5 (V-reg) had two separate keys, but the locks looked different and it had no central locking.
Post #108342 19th Dec 2011 9:35am
pjb
The fuel cap key is just for that, the ignition key should fit the door lock.
Before you strip it down I would give the lock a good dousing in wd 40 as it might just be seized due to lack of use.
My lock always freezes & I had to get in through passenger door & then struggled to lift up the lock mechanism.
They seem to collect water so you need to ensure a good dousing of a water repellant / lubricant to ensure easy operation.
regards locking with just a key you learn something new everyday Thumbs Up
extra security either steering disc lock or clutch claw or equivalent anything that makes it difficult to steal yours will encourage them to find easier pickings
good luck 2020 P300 HSE
Post #108344 19th Dec 2011 9:39am
Martin
Site Admin
Apologies with the mix-up about the keys, I thought they'd only very recently gone over to the ignition key working in the doors Embarassed  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #108356 19th Dec 2011 10:05am
