Home > Puma (Tdci) > Does anyone use a Radiator Muff during Winter?
Page 4 of 9 <123456789>
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
22900013A wrote:
johnszs wrote:
Thats the one
it comes with a fitting kit which has m5 screws and spring nuts. which go through the grill and spread holding the muff in place
I think we might just invest in one of those then. Am also looking for a heater intake snow cover but the prices are laughable...
let us know how you get on with nit fitting etc.
might get one ,bit cold today
Post #107392 14th Dec 2011 10:10am
BigMike
Or rather than fanny about with muffs, cardboard and builders bags, just change the thermostat for winter, then change it back in summer. easy.
Post #107405 14th Dec 2011 12:05pm
22900013A
Ordered mine from Paddock, will let you all know how I get on. Should have a wing snow cover soon too. 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #107902 16th Dec 2011 8:07pm
ZeDefender
Mine is just fixed with black cable ties - very smart and works a treat Thumbs Up Tell someone you love them today because life is short.
Post #107904 16th Dec 2011 8:12pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Well, having started this topic I have now fitted a radiator Muff purchased from Paddocks. I used spring loaded cavity wall fittings which would work well on non-puma radiators but with the slatted design on the puma standard grill you had to tighten the fittings a fair bit, thus pulling the fabric into the grill opening. Very un-satisfactory an if you pushed the fabric/fitting in then it would lose its grip on the radiator slat.
So I used 2 lengths of aluminium strip. about 1" wide, covered in black tape for aesthetics only with 2 holes in each near the ends and pushed the bolts of the fittings through the strip and fabric then fitting the spring loaded fitting and now it fits well and needs a screwdriver to remove it.
Have just completed a 600+ mile round trip to Norfolk from S.Wales with the radiator muff on and closed. Quick warm up. Water Temp, according to Scangauge, stayed between 88 to 90c normal on my 90XS. Fuel consumption 10.6L / 100Km and the return trip was 271 m in 4 1/2 hrs, virtually all on motorway and dual carriageway at 70+ . So very happy with the result.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #108072 17th Dec 2011 4:11pm
22900013A
I thought the Paddock one comes with spring fastners??? 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #108073 17th Dec 2011 4:35pm
ZeDefender
Very smart Thumbs Up Thumbs Up Thumbs Up
Also good to get the feedback about the water temp on the long trip. I am a lot more confident to leave mine closed now Very Happy
Matt Tell someone you love them today because life is short.
Post #108078 17th Dec 2011 5:44pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Will Scanguage work from a TD5 OBD?
Post #108079 17th Dec 2011 6:07pm
Happyoldgit
I've restored a few pre war cars in my time and one or two of them came with really nice quilted canvas rad muffs that fitted to the grilles by turn-buckles and had opening flaps that could be secured back with lift the dot fasteners. I've had others that had radiator blinds that worked just like a window roller blind which meant that pulling a cord on the dash would pull the blind over the front of the rad a corresponding amount - something like that wouldn't be too hard to fabricate for a Defender. Steve.
http://forums.lr4x4.com
Post #108085 17th Dec 2011 6:34pm
WelshGas
These are the fittings supplied with the Paddock Radiator Muff.
http://www.ebay.co.uk/itm/M4-X-90-X-50-SPR..._500wt_922 LANDYWATCH
Post #108087 17th Dec 2011 6:42pm
22900013A
Ahhh, very much like what my old series III had then - I'm sure I can make them work well enough. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #108102 17th Dec 2011 7:56pm
spudfan
Ireland
Was there not a warning not to block airflow to the intercooler on earlier engines? I used to cover the grill on the 200 tdi but always left the intercooler uncovered. Would it not also apply to the Puma or does it not matter if the airflow to the intercooler is blocked? 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #108138 18th Dec 2011 2:00am
ZeDefender
At least on mine, the bottom of the "main muff" stops well above the intercooler. When it folds down it fixes to pop studs so it doesn't go any further. Other designs fold/roll up, so no problem there either Smile Tell someone you love them today because life is short.
Post #108142 18th Dec 2011 9:12am
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
I have been following this thread with great interest and as yesterday we darted down to Berkshire to deliver some Christmas presents. When we got back the mpg was 26.3 I was expecting a bit more (travelling at 60-65 mph) and so I wondered if putting one of these muffs on might help? As I don’t have one just hanging around I got some cardboard and reinforced the edges with duct tape with plastic on the front and baking foil on the back. I cable tied it to the back of the grill and went out for a test. It seemed to warm up quicker and the gauge remained at normal once it was up to temp but I thought I noticed a drop in performance. This I would assumed is because I blanked the inter cooler also, so when I got back I removed it and dropped it in front of the radiator and it has seemed to do the trick as performance is concerned. It only covers ¾ of the rad leaving the top ¼ free. I won’t know if the mpg will go up until Tuesday when I do my yearly trip up and down the country to visit all my best customers and drop some hampers off for them. I shall of course report back here.
Post #108177 18th Dec 2011 2:58pm
WelshGas
With the air-con grill there is quit a gap at the bottom that is not covered by the Radiator muff. I certainly haven't noticed any decrease in power - can still take out X5's and Disco 3's on the Culverhouse Cross hill in Cardiff in 5th gear. Rolling with laughter Rolling with laughter LANDYWATCH
Post #108196 18th Dec 2011 5:46pm
