Home > Puma (Tdci) > leak through air vent(?)
OrangeAlpine
United Kingdom 2013 Defender 90 Puma 2.2 HT Alpine White
another day, another head scratcher (and leak) on the 90...
When replacing the door seals, which sorted the water ingress thankfully!, I noticed signs of water dripping down onto the footwell mat on the passenger side and on closer look it seems to be coming in through the air vent;
Still pretty new the the 90 and the quirks of the defender so today's question is;
Is this just a case of water getting in through the LHS bonnet vent and running down to this vent and then onto the mat? (2013, 90, 2.2 Tdci, no air con)
Its only noticeable during/just after heavy rain (which we've been getting a decent amount of recently) and looking through the workshop and parts manual hasn't helped me too much - so is this "just the way it is" or is something likely to be missing or leaking within the cooler/blower assembly that would be causing this?
Post #1078850 31st Oct 2025 1:19pm
Ianh
Either through wingtop vent and via ducting, noting there is a duck bill drain valve in the duct that is supposed to drain any water ingress but it gets blocked. Easy fix is a snow cowl.
Or it’s water from windscreen / bulkhead running onto heater motor / ducting. Ensure you have not lost the rubber strip on wing edge abutting bulkhead or that it’s fitted correctly.
Several topics on both if you do a search.
Post #1078853 31st Oct 2025 1:58pm
OrangeAlpine
thank you @IanH Thumbs Up - will have another look when the rain has stopped and do some more searches
S 2013 ('62) Defender 90 HT, 2.2 Tdci
2002 Discovery 2, TD5
Post #1078854 31st Oct 2025 2:27pm
Given that it appears to be coming from the top of the aperture, not the bottom, it could also be running down the inside of the bulkhead from the windscreen and dripping off the acoustic mat at the top of the aperture. Unfortunately it is not easy to see without some dismantling.
If it was originating inside the blower housing I would expect it to be coming from the bottom rather than the top of the aperture (which, incidentally, is the recirculation air intake to the heater, so if you set the heater to recirculate the flap should open and you might be able to see more).
Post #1078857 31st Oct 2025 2:55pm
Ianh
Good point blackwolf, I did not really look at the picture Confused
If due to windscreen frame to bulkhead seal some Captain Tolly’s creeping crack cure may help
Post #1078858 31st Oct 2025 3:36pm
OrangeAlpine
Thanks both and useful info Blackwolf, thanks.
It’s definitely from the top so I’ll check the windscreen/bulkhead as that makes sense from what I’ve been able to see of the water path so far - too wet now so looks like a tomorrow job.
I’ll dust of the capt T’s - my disco sunroofs and gutters are pretty much held together with that so I’m well versed with using it!!
Will update as and when I find out more or fix 2013 ('62) Defender 90 HT, 2.2 Tdci
Post #1078859 31st Oct 2025 3:40pm
