Home > In Car Electronics > Dashcam Placement
Graz
United Kingdom 2015 Defender 90 Puma 2.2 HT Scotia Grey
Dashcam Placement
Hi. I’m looking to hardwire a dashcam in and wondered where people have put there ones. I don’t want to take the headlining off and so am looking at mounting it on the dash or bottom of the windscreen.
Post #1078772 30th Oct 2025 3:31pm
Mine's at the top of the windscreen, since I found that lower down it really only got a good view of the bonnet.
It is possible to wire to the top of the windscreen by running the wires up the A-pillar behind the black plastic trim (2 screws) and then carefully tuck it into the headliner along the top edge of the windscreen. It is easier if you remove the sun visor on whichever side you coming from (2 screws) but not essential. There is no need to remove the headliner.
Post #1078775 30th Oct 2025 4:42pm
Graz
Thanks. I was concerned that the lower position may not provide the best view. I think I may try attaching it to the back of the rear view mirror and run the cable up the rear view mirror stalk.
Post #1078819 30th Oct 2025 11:09pm
