![]() | Home > Technical > Puma P0101 fault code I give up. |
| andy63 Member Since: 30 Jun 2023 Location: north east Posts: 841
Check your intake side..air filter and pipework..
Sensor supply and ground.. and make sure its the correct sensor with a digital output.. |
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2559
Regarding Andy63’s advice on the sensor. Many vendors incorrectly quote and supply the same sensor for the 2.4 and 2.2. Invariably they supply the 2.4 sensor to 2.2 owners.
Was the new sensor the same shape as the old one ? If I recall correctly the 2.4 MAF has a square edge at the bottom on both sides, whereas the 2.2 has a curve on one bottom edge. Can you remove your new MAF and post a picture of it and one of the label with the part numbers showing. See Andy63’s post in this topic for details. https://www.defender2.net/forum/topic96494.html?highlight=2+2+maf If that’s ok then the next thing to look at is the inlet manifold to check seals and for cracks. Rare but has happened before. Then the throttle body to make sure it is opening fully, as yet I’ve not heard of it having issues but if not fully opening it could. Note the TB on the 2.2 is either fully open when running or fully closes when engine is shut down. It’s function is to shut the engine down smoothly, nothing more than that. |
| Drawbar Member Since: 21 Oct 2025 Location: stafforshire Posts: 7
Big thanks
Will check in morning |
| All times are GMT |
