Home > Technical > Immobiliser.HELP PLEASE
mwestcrew
United Kingdom 2011 Defender 130 Puma 2.4 HCPU Baltic Blue
Im broken down at Lancaster services M6 Notthbound.
Vehicle won’t start.
Key out the red immobiliser light is flashing slowly.
Key in and ignition on the light is on solid. When I try to start the engine nothing happens at all
Alarm fob did nothing at all, changed the battery, still nothing, still no start.
No central locking fitted.
Anybody any ideas please
TIA 2011 130 Utility Body
2005 110 Van
Post #1078209 24th Oct 2025 8:14am
Ianh
I suspect a blown 10AS fuse. If you had central locking I would suspect a broken wire between a second row door and the b post. However you may still have the wiring even if no central looking.
So check 10AS fuses and if a replacement blows then check door wiring.
Ps when you changed the fob battery (CR2032) did you check there is no clear plastic insulator left on the battery for transit ( it’s happened before) .
Also have you re synced the fob, it may have lost sync. Process - with doors shut press lock 4/5 times in quick succession, then unlock once
Wiring diagrams
https://www.lrworkshop.com/wiring-diagram/...tem/active
https://www.lrworkshop.com/wiring-diagram/...em/passive
Fuse box’s
https://www.lrworkshop.com/electrics/defen...nd-headers
If not fuses or fob battery then remove Instrument cluster , remove wiring connector, shunt (use wire , paper clip etc to bridge ) pins 3 and 4 and see if engine starts. If it does it’s the cluster pcp . This is only on the 2.4
Post #1078232 24th Oct 2025 11:37am
Ianh
Did you manage to identify and rectify the issue ?
Post #1078318 25th Oct 2025 12:16pm
mwestcrew
Hi Ian
Yes I did.
I’d tried all sorts of things but in the end this is what made it work.
The fob had list sync.
Unplugged the 10AS and left it for 20 minutes
Removed the battery from the bob and pressed the buttons to discharge any capacitors.
Repowered the 10AS
Re-inseted the battery.
Held the fob near the tbe 10AS
Plipped 4 times quickly
5th plipped de-armed the immobiliser.
Thanks for you ideas and help.
Called loads of people who sucked their teeth and said that the box would have to go away for repair.
Happy days!! Only three hours late arriving in Fort William!!! 2011 130 Utility Body
2005 110 Van
Post #1078330 25th Oct 2025 5:09pm
Ianh
Defenders have a mischievous spirit and know just when to play up, invariably when your are on an important journey, and never at home when you have some spare time .
Glad the re sync worked. One thing to note for the future is a low fob battery is indicated by the red alarm light saying on when the engine is started and running. For those with central locking another Indicator is only one side of the indicators flash (not both as normal) when you lock / unlock the vehicle)
Post #1078336 25th Oct 2025 6:34pm
