TD5 to Puma Bulkhead Swap
I am to begin the Bulkhead swap soon. (TD5 > Puma)
First time swapping the bulkhead out on these and for added concern & complexity its an engine swapped vehicle too.The bulkhead has been freshly painted and prepped. Is there anything that I 'must' do before putting it onto the chassis? Any tips or suggestions or things I should look out for?
I have already aquired appropriate floor panels. As well as wiring harness 10AS but no gauge cluster as I may produce my own solution for that.
Red oxide Primer -> Gravitax stonechip
Java Black Paint
Click image to enlarge4.0 V8 Defender 90
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
