![]() | Home > Puma (Tdci) > Fault Code P0340-24 (28) |
| lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3527
l had exactly the same fault with my Transit (TDCi)
I discovered three of the glow plugs were faulty. One was shorted and two were open circuit. l replaced them but it made no difference. There was no power to the glow plugs, the relay had burnt out. Check you've got power to the glow plugs on cold startup. |
| andy63 Member Since: 30 Jun 2023 Location: north east Posts: 836
As your code relates to a camshaft signal failure that would be a good place to start..
Checking power and ground to the sensor..if its like mine on a 2.2 it receives a 5v supply.. If they are good if you could check the signal..preferably with a scope.. That should give you an idea of what is going on with the camshaft sensor.. I have a trace of mine at tickover.. But you could watch yours at cranking and see what's going on.. One the engine starts the camshaft signal is redundant I believe.. That's what you should see ..( they red trace ) The blue is crank sensor and green is no1 injector..just as a reference.. Click image to enlarge |
