Home > Tdi > Brake issues
anotherrick
 1997 Defender 110 300 Tdi CSW Rioja Red
Brake issues
This morning on my way to work a car pulled out in front of me causing me to do an "emergency stop"
Anyway no collision and a few hand gestures later we went our separate ways. However my brake pedal is very soft and barely stops the car. Got me to work and had a quick look underneath and all four corners who apparently leaks, brake fluid at level in reservoir.
Anybody any ideas. I still need to get home haha.
Car is a 1995 300tdi 110
Thanks.
Post #1078001 21st Oct 2025 11:44am
Johan_B
Sweden 2007 Defender 110 Puma 2.4 CSW Tonga Green
If the piston seals are old and worn I guess it is possible that your emergency brake caused them to give up. I had it happen on one caliper this winter, also in an emergency brake.
Either new calipers or rebuild the ones you have. I got new calipers since I didn't have the skills/tools/time to rebuild them.
If your pedal is soft and you don't have stopping power you should not drive it until sorted.
Post #1078003 21st Oct 2025 12:13pm
TexasRover
As one gets older and have been exposed to more and more older vehicles, some in longish ownership, you realise that some things keep popping up as needing replacement over time. Typically and convently these are the things that stay longest available for older cars. Brake calipers are right up there.
Rebuilding very doable and fun, but straight out replacements are cheap, readily available and more convenient if you are short of dry workspace and time.
For all four a rebuild might justify the effort as there will be saving to be had.
Post #1078014 21st Oct 2025 1:34pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Highly unlikely to have popped all 4 calipers at once, better chance of winning the lottery. I suspect any dampness you are seeing at the wheels is probably existing axle oil leaks from failing hub seals, especially as you say the brake fluid reservoir is still at level.
Might be a Flexi hose that is ballooning, need a second person to press the pedal while you inspect for this. Also, does the pedal sink if you keep your foot on it (hence, a leak or passing seal in master cylinder). Could also be the brake servo has cracked so you are not getting the vacuum assistance you are used to.
If you are unsure what you are doing/looking for then brake repairs are one thing I always suggest are left to an expert. No room for error or learning on brake repairs and the consequences of getting it wrong can be much, much worse than leaving you stranded at the road side.
Post #1078026 21st Oct 2025 5:21pm
anotherrick
Thanks for the above replies guys. Left the defender at work last night and used work car to get home n back in this morning.
Had a look underneath earlier and can't see anything obvious. The brake pedal has full travel with no resistance with or without the engine running. Cant "pump it up"
Fluid level remains the same. If I drive forwards/backwards around 5mph the brakes work (vaguely) but the pedal is fully depressed. Obviously haven't driven any faster than that.
So that's where im at.
Post #1078068 22nd Oct 2025 3:40pm
Mdm
recovery time to a workshop for some tlc now
Post #1078069 22nd Oct 2025 3:51pm
anotherrick
Yeh, can't move it till the weekend. Will need to check with my breakdown cover if they'll take it to a garage of my choice rather than their preferred or nearest.
Post #1078071 22nd Oct 2025 4:28pm
I suspect a master cylinder fault from what you've described. No pedal pressure with no loss of fluid suggest MC seals have failed. Hopefully not an expensive repair.
Post #1078072 22nd Oct 2025 5:06pm
Dinnu
As Blackwolf mentioned, the master cylinder non return valve seal has possibly failed, letting the fluid back into the reservoir. I had similar, if coming to a slow stop, the pedal would start creeping down. Was not a problem in a hard stop. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1078091 22nd Oct 2025 8:46pm
anotherrick
Had a final look today with the help of a colleague pressing the brake pedal. This time the leak was very apparent. The brake line that runs down the inside of the chassis had corroded towards the back end where one of the fasteners is.
Priced up the genuine part and it's expensive for what it is so probably going to make my own.
Anyway thanks again for the replies. Hopefully they'll be helpful for other people with similar issues.
Post #1078202 24th Oct 2025 1:16am
Aha, so the fluid level was going down, contrary to earlier reports!
That makes more sense, the most likely failure under heavy braking is a corroded hard line, closely followed by a deteriorated hose. That corroded hard line should have been picked up on an MoT, it won't have corroded enough to burst that quickly.
Post #1078221 24th Oct 2025 10:06am
anotherrick
Yeh my colleague was pumping the pedal like they were trying to stamp out a fire haha hence the more noticeable fluid loss.
I did have an advisory on the last mot saying brake lines covered in grease/other material.
Post #1078229 24th Oct 2025 11:13am
I keep the brake lines on mine coated in a light spray of Dinitrol. (Not on flexi).
That just leaves a layer of extra protection.
Or you can just use a light paint of Matt or gloss black, but the above is better for corrosion resistance and longevity, obviously only a light coat, not thick.
Just one leak will do it, but some vehicles have a brake bias valve so that there is always front or rear brakes always retained in case of a failure.
Does your year have one? TDi’s possibly didn’t have those? ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1078266 24th Oct 2025 6:59pm
That's not what the bias or proportioning valve does, it merely adjusts the rear brake line pressure according to load conditions. The protection from a burst pipe causing total loss of brakes is provided by the dual circuit master cylinder and separate brake circuits for the front and rear brakes. On an ABS vehicle.there are four circuits from the ABS modulator to the wheels, one for each, and dual circuits from the master cylinder to the modulator. I am not sure whether the modulator can protect against single line failure though, so it may be that functionally even an ABS vehicle is just dual circuit (certainly the Disco2 is functionally dual).
If you do lose one circuit on a dual circuit vehicle brake pedal travel will increase dramatically and disturbingly since the travel lost in the leaking chamber in the master cylinder has to be taken up. It is quite exciting when it happens!
Post #1078285 24th Oct 2025 9:15pm
Very articulately explained BW, these things are always good to learn.
I think you may get away with coming to a halt, but I think you’d soon know, as you say the extra pedal travel would be a very significant sign. And quite alarming too!
Beyond that it’d need immediate attention, fluid loss alone is one factor that would happen at a fairly rapid rate even with a single line leak.
Mines non ABS, non TC as well, to be honest I’m glad as those things can cause more trouble than they are worth imo so there is less to go wrong.
Great when working but, extra problematic when not.
I know that with ABS systems you can use a slightly higher pressure bleed process up to a certain amount a little more than say 8 - 10psi approx for pressure bleed for non ABS. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1078290 24th Oct 2025 10:10pm
