Home > Technical > Puma P0101 fault code
Drawbar
Hi
Defender Puma 2.2 2013
P0101 fault code
Just keeps coming back.
Have changed hoses MAF sensor/ Boost sensor/ MAF socket plug ok.
Have done smoke test and no leaks.
Remove code then drive 500meters and engine management light comes on and limp mode.
Engine starts first time runs great until limp mode.
Help.
Post #1078004 21st Oct 2025 12:41pm
Shafski
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
Silly question. Have you checked the air filter is fully “home” and the air box lid is locked in under the wing, (2 hinge like clips) and thus creates the perfect seal?
Don’t ask me how I know this Rolling with laughter Shafski
_________________________________________
2015 110 Montalcino Red Utility "Harriet" along with Puma on I.C.E
Post #1078006 21st Oct 2025 1:02pm
Drawbar
yes plus new filter fitted
Post #1078010 21st Oct 2025 1:19pm
Shafski
Then the simple checks are done…
Check out this thread
https://www.defender2.net/forum/topic92122.html
They do seem to love a limp mode..
Keep us posted - good luck Shafski
Post #1078027 21st Oct 2025 5:27pm
Ianh
Just to clarify,
1. have you replaced all 3 hoses, inc the elbow into the inlet manifold ? That one can hole on its underside.
2. Are you 100% sure the Intercooler is not leaking as they do fail at the crimped seam.
If elbow replaced, you are 100% sure it’s not the Intercooler and all the clamps have been checked I have heard of the inlet manifold having a crack in it and causing a P0101 fault, but only once so a potential cause but very unlikely.
I suppose the throttle body could have an issue and not be fully open, however I’ve not read any reports of that happening either.
Post #1078028 21st Oct 2025 5:52pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
I don’t know if this will help, but I’ve had p0101 five times in six years:
1. Elbow hose split, which a smoke test failed to find.
2. Intercooler seam split.
3. Upper hose.
4. Changed maf as a precaution & needed to put the original back!
5. Clamp needed tightening.
Hope you get to the bottom of it soon.
Post #1078030 21st Oct 2025 6:11pm
Ianh
On the MAF, some sites state the same part for the 2.4 and 2.2 and invariably send the 2.4 MAF. This is incorrect, they are different and a 2.4 one won’t work properly in a 2.2. Just thought it worth pointing out.
Post #1078034 21st Oct 2025 6:47pm
Drawbar
Thanks to everyone with there advice.
I tried everything and found the fault.
The smoke test never helped but compressor at 30psi found the leak in the intercooler.
Post #1078057 22nd Oct 2025 10:54am
Ianh
It’s a very common fault, it fails at the crimp seams.
Bell auto services make and sell the best high flow intercooler as a replacement. That will last a lifetime as all is welded. However I don’t think Pete has any left in stock and I’m wondering if he is going to get any more made. However he also recommends and stocks one from Airtec which is well made.
https://bellautoservices.co.uk/store/land-...tercooler/
You can get from Airtec direct as well https://www.airtecmotorsport.com/products/land-rover/defender/
You can’t take full advantage of the new high flow IC unless you have a map, however I noticed a good improvement to engine performance when used with new silicon hoses and upgrading the air intake pipework from the highly restrictive LR setup to a much larger bore circular hose.
Post #1078058 22nd Oct 2025 11:16am
Shafski
I literally fitted the Artec on the advice of BAS a week ago! What a difference!!! It’s incredibly well made, and night and day on the stock item. Shafski
Post #1078082 22nd Oct 2025 6:43pm
