![]() | Home > Wheels & Tyres (L663) > 20 Steel wheel for defender |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1312 ![]() ![]() |
Disco 3 / 4 the PCD, but LR only made a 19" NOT 20.
VW wheels fit. But T5, T6, were only 18" (even for the Amarok) All others I can find are alloys. |
![]() Click image to enlarge Just had a second thought. LR 18" wheels are steel white painted. BUT, LR did an alloy 20" wheel which looks like an 18" steel. ![]() would the thieves know the difference ??? Last edited by LR Nuts on 10th Jul 2023 8:08am. Edited 1 time in total |
DAP2022 Member Since: 16 Feb 2022 Location: Norfolk Posts: 121 ![]() ![]() |
I wanted something not worth steeling for parking at airport etc, but in retrospect someone selling 5x 20 defender alloys for £350……
Might just buy 5 😂 |
yes the PCD is the same 5x120.
But rolling circumference is very different as your road wheels are 20" and white steels are only 18", add the tyre aspect ratio to that and you could be looking at a much smaller overall rolling tyre. earlier Defender wheels DO NOT fit New Defender. |
Here is a list of LR wheels that have a 5 x 120 PCD
You will notice most will be alloys on these vehicles. So to find a 20" steel, is going to be difficult. ![]() ![]() Click image to enlarge |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2785 ![]() ![]() |
If it’s just for parking then why not just get a cheap set of take-off 18” steels - there are loads available out there?
Contrary to the incorrect information above, all the factory wheel/tyre fitments are interchangeable in terms of rolling circumference so there is no impact on speedo. As the wheels get bigger the tyre profile reduces to match, keeping overall diameter the same. |
"all the factory wheel/tyre fitments are interchangeable in terms of rolling circumference"
But you have to look at all the variables for that to be true. for instance I have 18" LR Wheels with Pirelli ATs 255.60.R18, where as the white steel wheels are 255.70.R18. Beware ! |
Which is why I said factory fitments
![]() Of course if you fit different size tyres then it will be different. The point is all the factory tyre/wheel size combinations are the same overall diameter for speedo accuracy purposes. |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
If it’s just the security of the spare wheel you are worried about, I bought a stainless steel, canvass covered 1.2m long motorcycle security chain from Halfords for about £50 for when I park at Airports and city centre hotel car parks. I take it off when I’m at home.
https://www.halfords.com/motoring/motorcyc...59862.html There is a 1.5m long version which you could rig tightly covering the locking wheelnuts by going twice through the carrier on the back door - the 1200mm long chain is just a bit short to do that. ![]() Click image to enlarge Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Mudlark Member Since: 14 Oct 2022 Location: North West Posts: 31 ![]() ![]() |
Terrafirma have this at about £90:
![]() Click image to enlarge I'd be interested to know if anyone has fitted these, and their thoughts, as I need some steel wheels for more serious off-roading. |
DrRob Member Since: 29 Mar 2017 Location: Hampshire Posts: 274 ![]() ![]() |
I wonder if those Terrafirma rims will fit over the larger calipers on the D300 etc? MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
1974 Series 3 Lightweight = "Millie" Many Range Rovers and Land Rovers over the years 😂 1949 80" - still in family since 1975 I use www.glenrands.co.uk Great independent specialist! |
I have recently fitted these TerraFirma steel wheels but did need the TerraFirma spacers as well in order to clear the larger calipers on my P400e
HardTopRog Member Since: 13 Aug 2025 Location: Bristol Posts: 5 ![]() ![]() |
Do you have photos of the terrafirmas fitted?
