Home > Td5 > Not wanting to start :-(
excossack
Thursday this week the Landy started first turn of the key after being asleep for a week or so.
Saturday morning, again started first turn of the key. During Saturday while sat around between recoveries at Oulton Park I noticed sometimes the car would crank for longer than normal and then start and other times, it was on the button.
Drove home OK and then this morning came to start the car and click.. Nothing. No crank.
Good voltage at the starter and solenoid clicks. But no start.
I did try taping the solenoid but no joy.
Stuck solenoid?
Rebuild kits are available but in my experience, they don't seem to last long... Sad 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1077339 12th Oct 2025 6:30pm
TexasRover
Burned contacts can cause that. You can buy replacements and change yourself. Of course can also be that the motor has packed up, but the contacts are a common fault. Typically however you get a few false starts before they completely let go
Post #1077343 12th Oct 2025 6:59pm
landy andy
In my experience they get sticky first so a few goes of the key and it will eventually go, but I’m sure they can suddenly completely fail.
Post #1077373 13th Oct 2025 7:02am
excossack
In this instance, its failed Sad Luckily, I was at home 1999 Defender TD5 110
Regards
John M0VAZ
Post #1077477 14th Oct 2025 5:37pm
revd
not too bad a job on Td5 if you have exactly the right length of 3/8 extension for the 15mm top bolt
Post #1077507 14th Oct 2025 8:22pm
excossack
i found mine was 17mm nut and the rest are 13mm. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1077614 15th Oct 2025 7:03pm
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
X8R supply a solenoid kit. I fitted mine about 5 years ago, been faultless.
Post #1077618 15th Oct 2025 7:47pm
revd
I had fair warning and replaced before I was stranded.
X8R supplied my solenoid kit, quality appears good and has worked fine for 12,000 miles.
The starter motor itself was a reconditioned unit so there was some history prior to my ownership
15mm bolt with flange head on 10mm thread - which would typically have 17mm spanner size
Post #1077642 15th Oct 2025 9:54pm
miker
Rebuilt my solenoid a couple of times now, and the symptoms sound right. I've never had the plunger get stuck, it's usually just arced the contacts away to nothing.
Turning the plunger, and giving the contacts an emery cloth and a quick bend can get you out of a mess if you're desperate. Just not for long!
Post #1077649 15th Oct 2025 10:39pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
First time I made this contacts change on Discovery 2 TD5 I was not prepared to remove "the nut", so I have changed all necessary parts of starter solenoid without removing starter from car. It is just very hard to look inside and clean it, but it worked. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1077655 16th Oct 2025 7:28am
excossack
Thanks all. Starter replaced and working fine. Smile 1999 Defender TD5 110
Regards
John M0VAZ
Post #1077706 16th Oct 2025 7:12pm
