![]() | Home > Maintenance & Modifications > Help with deciding on suspension. |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1105 ![]() ![]() ![]() |
For example:
https://www.lrparts.net/lrc2269-defender-f...DnEALw_wcB 2017 5.0 V8 Supercharged RRS SVR 2008 2.4 110 Utility Station Wagon XS. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8476 ![]() ![]() ![]() |
Do you actually need it? How old, miles and condition of vehicle?
Just fit standard again, lr R&D is pretty good and std shocks and springs for the average user using it as its intended work very well. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop Last edited by jst on 29th Sep 2025 10:35pm. Edited 1 time in total |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 600 ![]() ![]() ![]() |
I fitted new britpart budget set when I rebuilt mine. They were completely shot, no damping, at about 15k. I actually refitted the old ones off of my previous 110, which are Armstrong (?) so possibly dating back to 1989, who knows. These have been fine until now when the one rear is leaking. I’ve put long travel OME front kit on from Gwyn Lewis, not that I need it! Rear kit to match before Mot, hopefully. 1983 110 automatic OM606
Original 17-18 year old shocks and springs - 130,000 miles. 2017 5.0 V8 Supercharged RRS SVR 2008 2.4 110 Utility Station Wagon XS. Last edited by BrickBox on 29th Sep 2025 6:48pm. Edited 1 time in total |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3642 ![]() ![]() ![]() |
I got Britpart hot dipped galvanized turrets and spring seats and they were excellent. I still like to paint them black though.
I got 2x pairs of Britpart springs as wanted to test a bit softer spring rate on the rear. Mine sagged a bit over time, however installed exact same pair on rear of a HT 90 and they are still fine. Perhaps the extra weight of a CSW. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 831 ![]() ![]() ![]() |
Standard Springs and Boge Shox is a decent cost-effective option. You can pick up good 2nd LR springs from forums eBay etc.
Cheers for the advice all
![]() I have managed to find some ‘as new’ genuine HD 110 springs off a low mileage vehicle- so I’ve bought them. Ordered galv spring cups and holding plates. The Boge shocks sound like something I’ll be happy with for now. I think I’ll get the rear sorted now and then that’s brakes inc calipers/brake lines/suspension and bushes sorted on the rear. I’ll tackle the front brakes and suspension etc at the same time also in the new year. 2017 5.0 V8 Supercharged RRS SVR 2008 2.4 110 Utility Station Wagon XS. |
then yes you do probably need them. sounds like you have found a sensible way forward which is great. std is good stuff in my experience and take offs are the way forward if you can still find them. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Just to keep this thread updated. Slowly plodding through the refresh. New discs,pads,bearings and springs fitted. Just waiting on shocks. It’s been a good learning curve - I’ve always been put off doing the bearings on a solid axle vehicle. It was straight forward enough, just time consuming.
The new springs are off a 2014 110 USW - but they look different to my 2008 USW. These new springs don’t have the top 3 more compressed looking coils. So maybe mine had sagged, or my USW didn’t have the HD springs, or in fact mine were HD and these arent ![]() The new springs are longer and were an absolute pig to get into the spring seats. Whereas my old ones came out pretty easy. I look forward to seeing how the ride has changed, for better or worse. ![]() Click image to enlarge ![]() Click image to enlarge 2017 5.0 V8 Supercharged RRS SVR 2008 2.4 110 Utility Station Wagon XS. |
![]() Click image to enlarge For comparison- this was the original springs with the top 3 coils close together. ![]() Click image to enlarge I will get a side by side comparison picture of the springs before I fit the other side. 2017 5.0 V8 Supercharged RRS SVR 2008 2.4 110 Utility Station Wagon XS. |
Hopefully one of the final parts to the puzzle delivered tonight.
![]() Click image to enlarge Interesting to see Boge and Sach on the same damper - sister companies? Either way - oil filled and twin tubed. Advice on fitting shocks - what’s the best method as I have heard people over tighten the top fitting bolt and don’t allow for articulation? Cheers ![]() 2008 2.4 110 Utility Station Wagon XS. |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2509 ![]() ![]() ![]() |
Don't forget to prime them before installation Puma 110" SW
Original ones look like progressive purple/brown setup. And yes they have sagged.
Later usw ones you have could be stiffer and are non progressive so rate is constant. Will feel firmer/harder low weight, similar to yours (when new) with a heavier weight. Fit rear spring no shocks and jack up opposite end of axle and jack down one you are trying to seat. Mind brake lines. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2363 ![]() ![]() ![]() |
Where did you source the dampers? I need to replace mine > 110 XS Double Cab
