Home > Technical > Defender wiper sweep
Page 2 of 2 <12
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
1960's design engineered into a modern day icon.
Post #681877 26th Jan 2018 5:06pm
okami
United Kingdom 1993 Defender 110 200 Tdi SW Montpellier Red
Definitely wheel box and/or cable wear. In many cases the wheel box wear is due to eventual bending and misalignment of the gear as it meshes with the cable. The brass collar that sandwiches the gear to the wheel box frame also gets loose and allows the gear to ride off the cable at times. Both are usually from banging on new wipers and ferrules.
Given the pain of replacing them, I'd recommend buying new LR parts. You WILL need to adjust (bend) the wheel boxes cable clamp to align and mesh the gears perfectly with the cable. You will also want to hammer on the ferrules onto the wiper while it is off the car (align it as couple of times first before fully seating it). This is to prevent the gear from pushing out of alignment and the brass collar from getting loose.
While you are at it:
New L/R wheel boxes
New cable (grease the heck out of it)
New wipers
New wiper motor gear (ensure it is the right one that matches your wheel box gear pitch and degree)
Properly adjust the wheel box clamps
Properly adjust the wiper motor gear backlash (use the included washers that come with the motor gear)
Grease inside motor unit
New park switch (keep the old one as a spare)
I had tons of issues with non LR wheel boxes and not properly aligning things. I've also seen the alignment undone by a heavy hand installing the ferrules/wipers. Do it once and do it right Very Happy
-j
Post #681903 26th Jan 2018 6:01pm
zsd-puma
Quote:
That leaves the motor worm drive, drive gear and the cable connection at the motor end being common to both wipers.
I did mention that a few posts ago....
If you're pulling the motor out, just get two new wheel boxes and a rack too, because it's not much more work or expense to replace those at the same time.
Post #682137 27th Jan 2018 7:32pm
jst
My 90, 88 vintage has excessive sweep all the time.
It appears the reviews owner replaced wheel boxes. They look new and lots of stuff was done prior to my my.purchase, like new bulkhead so it would stand to reason wiper boxes were new.
There is no slack between wiper arms or between both arms vs motor.
Do I recall there being a different motor gear setup and that fitting the wrong gearing gives wrong sweep, Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1077095 8th Oct 2025 9:42pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
Post removed- incorrect. 1983 110 automatic OM606
Post #1077115 9th Oct 2025 8:35am
Tooth count on the motor gear won't affect the sweep of the wipers, just the speed. The only things that will affect the sweep are the diameter (tooth count) of the wheel-box gears and the offset of the crank on the motor gear.
I think that the wheel-box gear size did change at some point (it's mentioned in some thread or other on the subject) so using non-standard wheel-boxes might affect the sweep. Similarly using a non-standard motor gear (i.e., one with a different crank-offset than expected for the wheel-boxes) will alter the sweep.
Over the years for different applications there has been a great variety of crank offsets used in what is essentially the same motor.
Post #1077118 9th Oct 2025 9:16am
MarkBrown
Post removed- incorrect 1983 110 automatic OM606
Post #1077122 9th Oct 2025 9:54am
Retroanaconda
The numbers on the gears refer to the sweep angle, not numbers of teeth. As above this is adjusted by the position of the crank on the gear.
The pre-2002 and 2002-on setups differ, you just need to match the motor gear to the wheelboxes. The motor itself is the same.
Post #1077129 9th Oct 2025 10:41am
jst
Thanks you.
Well.they are def the older style spindles and hence I guess wheel boxes as have the grub screw fitment.
So guess need to look at crank. Could be old style wheel boxes and newer motor with different crank position? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1077187 9th Oct 2025 9:17pm
jst
517646 - 115deg wiper motor crank and gear
DLW000020 - 140 deg version Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1077215 10th Oct 2025 8:54am
jst
new reduced arc crank fitted, if doing this move the park 'wedge' to correspond with the crank and wedge coming off. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1077572 15th Oct 2025 11:32am
Page 2 of 2 <12
