Home > Puma (Tdci) > Rust Proofing
LR09WA
Australia 2009 Defender 110 Puma 2.4 SW Stornoway Grey
Rust Proofing
Does anyone know which panels on the new defender are steel or need rust proofing. eg fire wall, floor pan etc
Post #10734 12th May 2009 9:05am
Pob
United Kingdom 2008 Defender 110 Puma 2.4 HT Rimini Red
I think it's steel bonnet, side doors and back door, bulkhead and of course chassis. So actually quite a lot of steel.
Post #10735 12th May 2009 9:45am
Grockle
Just a note,regarding corrosion,if you fit stainless steel bolts which some people do,this speeds up the reaction between the steel and alloy panels as you then end up with three different metals Thumbs Up 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #10737 12th May 2009 10:03am
mse
I thought they had ali bonnets now, obviously not Mike
Post #10775 12th May 2009 7:34pm
LR09WA
Thanks Pob when I get mine I will run a magnet over all the panels to see which ones I need to rust proof
Post #11733 9th Jun 2009 7:03am
Grockle
Best rustproof all panels as the alloy ones can corrode. 2.4 90 XS
Post #11737 9th Jun 2009 8:07am
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
I was looking over mine and pulled off all the door seals and the previous owner had a roof rack with lights and run the wire behind the door seal.
euughhh, the water ran down the wire and corroded the lip the seal sits on! It's cleaned up well but left unchecked this could have been ugly, the other side was rusty too.
I wire brushed it and painted rust inhibitor onto it, then smeared waterproof grease all over.
GROCKLE, Thanks for the heads up on the stainless screws because I was going to get some.
EDIT: Mines a 2000 td5 but no reason you shouldn't be aware
Steve
Post #11738 9th Jun 2009 8:28am
