Home > In Car Electronics > 2008 LS Swapped Puma Instrument Cluster
RocketSpeedShop
Estonia
Hi,
I'm working on finishing 6.2 L92 Swap with BMW ZF Transmission for 2008 110 2,4 Puma.
I'm running MaxxECU Race for the engine, so I can design and send custom CAN messages to make rest of the electronics happy.
Can somebody share or guide me to information about CAN Protocol in 08 Puma to make instrument cluster work?
I have the warning ligts working but RPM, coolant Gauge need something more. Also any other information is welcome if A/C and ABS require something more.
Edited: TD5-Puma confusion.
Post #1077439 14th Oct 2025 8:02am
jonny
I'm pretty sure that the gauges aren't fed from CAN - the speedo head is fed with analog outputs from the ECU, which the speedo then uses to drive the gauges.
Easiest solution would be to run the gauges directly from standalone sensors - most people choose the VDO cockpit vision range which are a close match to the standard gauges.
Post #1077443 14th Oct 2025 9:13am
RocketSpeedShop
Estonia
I'm confindent that the speedo is CAN controlled. Engine light, battery charge indicator, glow plug indicators are already working at 0x127. Without any input the temperature gauge dial is maxed. With right bits I can make the gauge go to 0 position (possibly to do with some malfunction flag?)
The tachno seems to be 0x0F6 but I'm unable to get indicating.
I'm not a LandRover specialist but it seems to be the Puma instrument cluster. There is also a CANBus controller for some OE applications:
https://www.defender2.net/forum/post583887.html
Post #1077445 14th Oct 2025 9:38am
jonny
The TD5 instrument cluster is not CAN controlled, but the Puma one is...
@Martin on here has a CAN controller for the Puma cluster I believe, so may be able to advise on the CAN messages required...
https://fnltd.co.uk/shop/puma-system-controller-p114.html
https://fnltd.co.uk/shop/puma-gauges-controller-p87.html
Post #1077448 14th Oct 2025 9:45am
revd
Surely 2008 donor is Puma not Td5
Post #1077449 14th Oct 2025 9:49am
RocketSpeedShop
Estonia
Okay, thanks for the clarification! It used to be 5cyl turbodiesel. Not really familiar with all the naming.
Post #1077450 14th Oct 2025 9:54am
jonny
Does the cluster look like:
Or:
First is a puma cluster, second is TD5. If the engine had a 5cyl diesel and the first cluster, then something else has been swapped round to start with - it's not standard...
Post #1077451 14th Oct 2025 9:58am
RocketSpeedShop
Estonia
Okay, This is a bit embarrassing but yes, it used to be 2.4 4-cylinder Puma and yes it has the Puma cluster. Laughing
Anyway- question is the same.
Post #1077452 14th Oct 2025 10:07am
jonny
this might help:
https://github.com/posmanet/DeCANder/tree/master
If you look through the code within the project (the .ino file), there's definitions for most of the CAN messages which you could reverse engineer..
eg:
if (canID == 246) {
rpm = (canBuf[4] - 96) * 256 + canBuf[5];
RPM is 4th bit of message 0x246, offset by -96, multiplied by 256 + the 5th bit?
Post #1077453 14th Oct 2025 10:22am
