Home > Puma (Tdci) > Loss of Power - VCV or Fuel Pressure Regulator
MGRGPGBG
United States 2009 Defender 110 Puma 2.4 SW Alpine White
Searched the forum and various posts are on the same subject. Loss of power while accelerating after shifting mainly but at times while just cruising. At first assumed the is a VCV issue but plugged in the Gap tool and it showed P0089-7A (2Cool Fuel Pressure Regulator...per the picture attached. Thought great easy fix I hope....cleared the code and issue is still there but the code has not appeared again. Popped the hood (bonnet) to look at the fuel rail and noticed a ton of wet diesel soot on the intake manifold. No idea if this is related. Pics attached too. Not sure what to look at to diagnose the issue - any recommendations?
Post #1077020 7th Oct 2025 7:35pm
I was wondering if it was the Pressure Relief Valve, which is VCV associated, but I’m unsure if it would run at all if that had gone.
Blackwolf on here, may possibly be along with some details on these type of faults, but if the PRV goes, you can only but replace it. But it isn’t that common.
Did you replace the VCV or just presumed?
have you checked around the injectors that they aren’t wet?
Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1077026 7th Oct 2025 9:20pm
irishhawk11
Austria 2011 Defender 90 Puma 2.4 HT Santorini Black
Strange picture, as the suit is all around the air intake manifold.
I don't believe it is the VCV or PRV as it is clean but anyways, have a closer look at the PRV. As mentioned this needs replacement when it was triggered, bit again this has a fuel return line and shouldn't spray fuel.
I would also recommend to look around the injectors.
Post #1077042 8th Oct 2025 9:02am
On a 2.4 the VCV is the fuel rail pressure regulator, there is no other way to modulate rail pressure.
Do not confuse the pressure release valve on the rail with a regulator, the PRV is simply there to protect the injectors etc from excessive rail pressure in the even of VCV malfunction. The PRV is a non-resettable valve, once popped it must be replaced (although it is not unknown for them to leak).
Post #1077055 8th Oct 2025 10:26am
MGRGPGBG
I have not changed the VCV - I did put a new one in about 30k miles ago when I built my truck.
Will pull cover and check injectors - they should be OK as I had new seals and washers installed at a service last winter.
Any idea on the soot issue?
Thumbs Up
Post #1077146 9th Oct 2025 1:27pm
MGRGPGBG
If the PRV did pop, would the error code come back after I cleared it? I have been driving a few days and the issue persists but no codes on my reader now.
Also noted that this happens only when the engine is at running temperature.
I get a puff of white smoke out of the exhaust when I feather the throttle to get it out of this loss of power condition, or if I can get enough RPM's to shift up and then back to normal running.
Post #1077147 9th Oct 2025 1:31pm
If the PRV had popped you would permanently experience extremely low fuel rail pressure and would not be able to drive normally. It is less certain that you'd get a DTC, since the 2.4 fuel system is very poorly covered by diagnostics.
If the PRV was leaking you may still get reasonable running but with incorrect rail pressures.
You oily gunk looks to me more like it might indicate a leak in a boost pipe, which is unloading oily induction air over the manifold. It doesn't look to me like a fuel leak from above.
Probably 90% of 2.4 Puma fuel-related problems are due to the VCV malfunctioning. Generally any kind of misfire, erratic idle, lack of power. or poor performance particularly when sudden changes in engine demand are made, especially if there are no DTCs, will be down to the VCV. There also seems to be a growing and disturbing trend for new VCVs straight out of the box to be defective. Bearing in mind how (relatively) cheap the VCV is, it is usually a sensible first step to change it, since in most cases - but not all - it will the problem.
Post #1077153 9th Oct 2025 3:02pm
I think the most likely DTC that would be logged would be fuel rail related due to low pressure malfunction, provided it got to at or below the threshold that it would kick in to trigger logging the code.
Check the Turbo vanes are free and the actuator is working as it should too, yes, again a big malfunction would create a DTC for this, but it doesn’t always get to the stage of triggering a DTC.
White smoke iirc means slightly on the lean side on fuelling, blue tends to be oil burning which is not good at all! Black, rich on fuel.
You do get more steam in cold / wet weather as well, on cold starts in very cold weather a little more smoke, but will soon clear.
You really could do with seeing live rail pressure, but you’d need the expected parameters to compare against. I expect you can find this on here or online. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1077191 9th Oct 2025 10:00pm
MK
White and smelly smoke indicates excesive/unburnt diesel. Puma 110" SW
Post #1077192 9th Oct 2025 10:14pm
