![]() | Home > Maintenance & Modifications > New steering wheel |
RoadForce Member Since: 17 Jul 2014 Location: Holland Posts: 357 ![]() ![]() ![]() |
That 3rd photo shows quite a "deep" steering wheel, keep in mind that this increases the distance to the wiper and indicator stalks unless it comes with quite a shallow boss. I have a plain/flat steering wheel from paddock's, but it has a fairly high boss, hence the distance to the stalks is somewhat increased but still manageable. It was fairly cheap, about 45,- roughly 10 yrs ago. I see it goes for about twice that nowadays though, see DA4650 on their website. Defender 130 HCPU Td5 MY2000
Oh by the way, I heard some bend their stalks to overcome the increased distance... Defender 130 HCPU Td5 MY2000
robbiedondo Member Since: 12 May 2023 Location: kent Posts: 2 ![]() ![]() ![]() |
I've one of the wooden ones, zero /minimal rise on an Optimill slimline steering boss
comfy to drive with and not a problem in the winter, you need the slimline boss/zero rise as otherwise its too close to you and the switchgear is as well miles away the only issue I have is the steering lock takes a bit of atoll Regards Rob |
Betsy Member Since: 05 Aug 2024 Location: Derbyshire Posts: 43 ![]() ![]() ![]() |
Thanks chap, what has the steering lock done?
Thanks chap, what has the steering lock done? |
Thanks fella, il take a look at that paddocks one |
Can you get a slim line boss for the Mountn y one you have |
I don't recall, it's been a while. Better check with paddock's. Not that mine sits uncomfortably high, I quite like it but obviously it depends on your personal preference and body characteristics (eg arm length). The distance to the stalks is quite workable for me, medium sized hands. Defender 130 HCPU Td5 MY2000
Puddings 3112 Member Since: 05 Dec 2020 Location: Down South Posts: 51 ![]() |
I have had the wooden momo fitted for 5 or 6 years now and find it nice to use on and off road although if the power steering decides to take the day off, it is noticeably heavier to turn than the genuine original in slow parking manoeuvres.
I have it mounted on an optimill detachable boss so that I can run their boss lock so do not have any wear issues from a steering wheel lock |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2522 ![]() ![]() |
The optimal quick release boss and swivel lock combination are the ideal combination for security and ease of use. I would recommend their use on whatever wheel you go for, noting they do fit the mono range of steering wheels, but you do need to double check.
Trev Member Since: 01 Jul 2023 Location: Fife Posts: 36 ![]() ![]() ![]() |
I have a leather MoMo with with an Optimil quick release boss (so I can use their lock) and I'd recommend it.
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2543 ![]() ![]() ![]() |
Agree with Trev, Momo wheel, Optimil QR boss and Optimil lock. Fitted them a number of years ago, the ideal combination. Thoroughly recommend. Defender 90XS SW
