Home > Td5 > TD5 Exhaust Manifold
jonny
Hi
I'm looking at options for an uprated manifold for the TD5.. It seems there's a couple of options:
Allisport - about £700
Various ebay modified standard manifolds - £2-300 including studs, gaskets etc. Some claim to be de-webbed/skimmed/heat treated etc
https://www.ebay.co.uk/itm/226895163874
https://www.ebay.co.uk/itm/314316494193
Unless the Allisport one is proven to be 'better', any recommendations for reputable suppliers for a modified standard one?
Post #1077078 8th Oct 2025 6:51pm
landy andy
The promade ones are nice but £££££
Personally I dewebb my own, then get all faces skimmed.
Not had a problem after.
Just don’t buy one that hasn’t yet warped. You want warped, then sort it.
Post #1077084 8th Oct 2025 7:50pm
bankz5152
Allisport one is made by CJM in France.
Its a excellent manifold and very good if your running a hybrid turbo or VNT, helps when trying to squeeze more bhp and lower EGTs. However they can still warp, mine did after about 40k.
The TotalTd5 ones are well proven, heat treated, destressed and work well for standard tune and moat other applications if your not chasing numbers.
Post #1077085 8th Oct 2025 8:05pm
landy andy
I have a spare standard manifold that is warped if you require one to borrow so you can keep your vehicle on the road.
Post #1077111 9th Oct 2025 8:04am
jonny
Thanks. At the moment I'm looking at known weak points and options for fixing them before they cause an issue - just trying to figure out if the allisport/CJM ones are worth the extra money over a 'fixed' standard one Smile
Post #1077119 9th Oct 2025 9:18am
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
Re: TD5 Exhaust Manifold
jonny wrote:
Hi
There used to be a chap in Beverley East Yorkshire who had a machine shop and small forging business who used to do an exchange service for £75 where he would deweb, normalise then machine all the faces.
Ill see if I can dig out his details.
Post #1077126 9th Oct 2025 10:25am
rustandoil
I have a exhaust maifold from Allisport, been on nearly 10 years ....no problems Thumbs Up
I should have picture somewhere Very Happy
Post #1077128 9th Oct 2025 10:36am
Typical, I binned a (warped) manifold a few months back... couldn't give it away on here. Rolling Eyes
Post #1077204 10th Oct 2025 5:44am
TexasRover
Also the be safe install with longer studs with spacers. This gives the studs more flex and avoilds pulling the stud out maybe
Post #1077212 10th Oct 2025 8:45am
