Home > Td5 > Drain funnel in Door
foremanyvr
Canada 2002 Defender 110 Td5 DCPU Coniston Green
In the door of my 110 there are these black funnels.
I'm missing one and also need to know how to put back in their correct location.
Does any know the part number or diagram on how I put this back correctly?
Thx!
Post #1076925 5th Oct 2025 11:38pm
TexasRover
Never seen that before. What year is it? I probably never opened a later rear door. Looking good otherwise!
Post #1076932 6th Oct 2025 7:34am
donmacn
Not seen one like that either. If you look at the parts diagrams you can find something that does a similar job (sorry, can’t do that and give a part number at the moment).
When I fitted new doors to my car I decided to try them (they weren’t in the doors I bought the car with, though I have a suspicion they might also have been replacements and that the garage that did the work were less than scrupulous in their working standards…)
I wonder if that isn’t a DIY attempt at the same thing? Though if it is, I’d have thought the outlet pipe was in the wrong place? I.e. nothing is going to drain through it as it’s too high. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #1076935 6th Oct 2025 7:51am
I also have never seen anything like that in a Land-Rover door and certainly as it is in the photograph it serves no purpose at all.
I'd bin it and go without.
Post #1076937 6th Oct 2025 8:33am
markb110
I have them in my 2002 90 TD5.
But not in that position, it has fallen out of its further up location
I don’t have a picture but from memory it is fits towards the back of the door. It kind of just slots in place.
Remove the weather shield, plastic or foam, remove the metal panel, keep the window up and it should make a little more sense
Someone must be able to pull up a drawing to help you.
Post #1076942 6th Oct 2025 9:54am
I've scoured the parts catalogue from 1987 on and there is nothing that even looks vaguely like them in any of the side doors on any '87-on Defender.
Post #1076951 6th Oct 2025 12:54pm
foremanyvr
It's a 2002 110 Dual Cab
I'll see if I can find where it slots in but I need one more.
The previous owner had some work done on one of the doors and it's missing.
Thanks!
R
Post #1076966 6th Oct 2025 4:38pm
landy andy
Couldn’t you get one 3d printed for you??
Post #1076974 6th Oct 2025 6:11pm
