![]() | Home > Puma (Tdci) > puma clutch |
So take it back.
Landyrob Member Since: 07 Jul 2011 Location: Switzerland Posts: 93 ![]() ![]() ![]() |
sound's like the springs are a bit loose... LANDROVER Defender Best 4 x 4 x Far
Defender TD4 90 Hardtop 2.4 Defender TD4 110 Hardtop 2.2 |
nivmargalit Member Since: 19 Apr 2011 Location: under the sun Posts: 30 ![]() ![]() ![]() |
next week I will be there , let's see what they will say. |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
Are you sure that its not the EGR self-cleaning cycle you can hear? Pete |
When I push the pedal i do not hear the noise. |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4812 ![]() ![]() |
Definately a clutch that needs changing. Same symptoms as mine ie. pedal depressed no rattle on turnoff, before it was changed. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
update
I have been at the dealer shop they advise that this is a normal noise. nothing left me to do but pray that it will not get worst. ![]() |
skhyam Member Since: 31 Dec 2011 Location: London Posts: 1 ![]() ![]() ![]() |
I had noises
![]() ![]() I got this from another forum - I hope it is useful Land Rover Service Bulletin Models LD - Defender LTB00166 Subject/Concern: Clutch Noise/Poor Selection Models: Defender (LD) 2.4 Puma Diesel Engine. 2.4 Puma Diesel Engine. VIN-range: 7A732615-9A766150 Markets: All Section: 308-00 Summary: Potential difficult gear selection and noise in clutch operation. Cause: Improvements have been made to the specification of the clutch plate and clutch cover to address both the potentially difficult gear selection and noise during clutch operation concerns.Suggested customer concern code P24. Action: Should it become necessary to install the clutch kit assembly, refer to the new procedure detailed in Global Technical Reference GTR Workshop Manual, section 308-00. Parts Required: Description Part Number Quantity Clutch kit Assembly. URB500080 1 Labour Time: Operation Description Operation No. Time Clutch kit Assembly Renew. 33.10.01 3.9 hours Repair/Claim Coding: Causal Part: URB500080 ACES Condition As said, they only action it if you complain, its not actually a recall. I know of quite a few needed doing Good Luck ![]() |
MaxD90 Member Since: 26 Sep 2011 Location: Dominican Republic Posts: 12 ![]() ![]() |
Ohhh yeah,,,,,, take it back, you need a new clutch kit. It happen to me, the warranty cover you. You'll notice the difference. Good luck One life, live it.
Take it back 130's have feeling's as well you know
iruffell Member Since: 03 Sep 2010 Location: Marlow, Buckinghamshire Posts: 343 ![]() ![]() ![]() |
Just had mine done under warranty the difference is amazing, no rattles and no clonks when changing gear.
cinstone Member Since: 29 Nov 2010 Location: Stourbridge Posts: 375 ![]() ![]() ![]() |
Thanks for the VIN number range. Guess who's VIN is slap bang in the middle of the range
![]() Just under 41k miles now. It's still going, but for how long? Chris. http://shropshirelandrovers.freeforums.org 2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW. Previous LR's: Michael, my 2008 Defender 90 XS SW. Machinas oportet intrare non capsicum annuum faveo |
CRJ Member Since: 12 Mar 2011 Location: Sealand - Denmark Posts: 253 ![]() ![]() ![]() |
The labour time 3.9 hours - is that what an authorized dealer is expected to use changing the clutch?? CRJ 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
No, it is the number of hours labour Landrover will pay the dealer for doing the work under warranty, and is generally less than the number of hours the job actually takes, and also generally less than the times listed in the official Repair Times Manual. |
