Home > Tdi > Reverse light switch location
Mr110td5
Hello,
I'm struggling to find where the reversing light switch is located please?!
Post #1076043 24th Sep 2025 7:41am
el sid
England 1996 Defender 90 300 Tdi CSW Barolo Black
ns of gearbox,hard to get to from underneath.
Post #1076482 29th Sep 2025 5:21pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
I thought it was on the top of the turret, so below the tunnel. You maybe able to get at it by removing the rubber boot. Or you may not. 1983 110 automatic OM606
Post #1076484 29th Sep 2025 6:02pm
donmacn
^^^ I think it’s one of those things that’s awkward either way - from underneath, or from the top via the opening in the tunnel. (Edit - I agree though, it’s up just underneath the turret.)
An alternative (only time consuming the first time) is to cut out a section of the tunnel, keep the cutout section, and use it as a “hatch”. Once upon a time I had issues with my Roamerdrive shift lever and by far the easiest option was to make an opening to allow adjustment, rather than taking the whole tunnel off. I find that a disproportionately awkward job. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #1076495 29th Sep 2025 7:28pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Distant memory here as I last had a 200tdi in 2007'ish.
Pretty sure the reverse switch is easily accessible with just lifting the cover under the centre seat?
Like I said, quite a while ago, but only a butcher would find it necessary to cut holes in the bodywork to access something that's rarely accessed and also quite easy to get at.
Post #1076512 30th Sep 2025 12:11am
donmacn
I can’t quote the last reply, but I think it’s quite out of character for this forum.
You weren’t there; you don’t know the configuration of my vehicle; nor how I re-instated the patch afterwards. Maybe not be so quick to rush to judgement and throw insults around? Donald
in the past..
Post #1076521 30th Sep 2025 8:15am
Retroanaconda
You don’t say what kind of Tdi you have, they use different gearboxes which have the reverse light switch in different locations.
LT77 (for 200Tdi) has it on the back of the selector housing. Fairly easy to get to with the centre seatbox panel removed.
R380 (for 300Tdi) has it on the left hand side of the extension housing, a bit harder to access.
Post #1076528 30th Sep 2025 9:03am
Mo Murphy
Both are doable from under the centre panel of the seat box.
50 Shades of Pennine Grey
Post #1076562 30th Sep 2025 2:02pm
