Home > Tdi > 200 TDI sounding rough
Procta
Hi lads, what would make a 200 TDI sound very rough when 1st started? it sounds like its running out of fuel? My dad also thinks its under powered too. we changed the lift pump that failed two months ago, my dad put the spacer on that came with the lift pump. I am right in thinking it shouldn't really have one on? They are a way with it at the moment, but my mam is worried about it. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #1076331 27th Sep 2025 7:32pm
jst
Didn't we have all this a while back with not starting . Gave a heap of advice then. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1076340 27th Sep 2025 9:11pm
Procta
yeah and we got it running, replaced fuel gauge, sender unit, fuel pipe, fuel lift pump. Its driving now and back on the road, but it sounds very rough on tick over when 1st start up, as i mentioned. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #1076354 28th Sep 2025 1:50am
mini Anaconda
Air in system? Any leaks from injectors, injector leak off pipes? (Or leaks from anywhere else fuel related?)
When did you last change your fuel filter? BORG - Bucks & Oxon 4x4 Response Group
Post #1076366 28th Sep 2025 8:43am
