|  | Home > Maintenance & Modifications > Front swivel pin replacement |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8486      | Swivel ball can stay on axle for bearings to be replaced. Wheel off, hub off, cv out, outer swivel off by undoing 2 bolts holding top and 2 bolts on bottom king pins.. refit and set preloaded with shims using spring balance or by feel.
 Brake bracket that holds flexi may need taking off, adapting with top King pin if it's fitted. I would be tempted to change swivel chrome ball and seals of you going in that far form the age of vehicle if its on original setup. Also consider having bearings to hand so a judgement call can be made whilst in there Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop | ||
|  27th Sep 2025 10:15am |
| Cruiser100 Member Since: 26 Sep 2017 Location: N.ireland Posts: 78      | Thankyou! | ||
|  27th Sep 2025 6:25pm |
| PauloA Member Since: 29 Apr 2024 Location: Bristol Posts: 45      | The Haynes Manual is useful for this task, it's got the all relevant torque values in as well as the 'pull-off check' details you'll need if you replace the bearings and/or shims. Cheers,
 Paul | ||
|  27th Sep 2025 7:08pm |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18038      | The genuine Land-Rover WSM (which is freely available on this forum thanks to the generosity of a forum member) is superior in almost every respect to the Haynes offering. | ||
|  27th Sep 2025 7:44pm |
| PauloA Member Since: 29 Apr 2024 Location: Bristol Posts: 45      | Absolutely WSM is better but the Haynes is workable and many people probably already have one sitting around the garage!
 Either way there's a couple of things about doing the job that you wouldn't necessarily know unless someone told you so finding a reliable reference source is important  Cheers, Paul | ||
|  27th Sep 2025 9:12pm |
| Jurassic Defender Member Since: 28 May 2025 Location: Lisbon Posts: 13      | Just did it in mine and made a video to help out, if you have a Td5 do replace the pin for the 300 Tdi one
 https://youtu.be/ETmRdW6trq4?si=5pgNLkyuuU0WpfWc   Click image to enlarge | ||
|  28th Sep 2025 11:57am |
| All times are GMT + 1 Hour | < Previous Topic | Next Topic > |
| Posting Rules
