![]() | Home > Puma (Tdci) > Needing help with high level brake light. |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3635 ![]() ![]() ![]() |
There are 3 connections on the glass.
One side there are 2 spade connections. One is the heater 12V supply and one is the 3rd brake light 12V supply. On the other side there is one spade connection which is the ground. On the glass you can follow the 'element' that is going all the way up to the 3rd brake light (should the the outer one. Just bridge a wire from the spade connection to the same side of the brake light. Do the same for the ground. You can push the wire behind the rubber seal to make it more tidy. Hope this helps. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
MussEd Member Since: 20 Feb 2013 Location: East Lothian Posts: 374 ![]() ![]() ![]() |
Thanks!
