Home > Technical > Defender 90 rear shock absorbers
Page 2 of 2 <12
Tractorman
Scotland 2011 Defender 90 Puma 2.4 HT Indus Silver
Many thanks for the further advice. It is strange that my Defender failed its MOT at 4 years old in 2015 and at 24k miles - worn rear shock absorber bushes. On the basis that these was original factory fitted shocks it didn't say much about Land Rover quality - maybe I was unlucky.
Post #1037759 18th Jun 2024 10:12am
Vitesse
I have had my Puma from new in 2015. It’s done 95k and have replaced the lower rear shock bushes 3 times. The shocks are still very good 2015 90 XS Santorini Black
Post #1038625 28th Jun 2024 11:59am
TexasRover
Bushings are cheap and easy to replace. Unfortunately rubber quality is unpredictable so you might need to replace quicker than you had wanted.
Shock (to be correct dampers) either fail outright (oil loss etc) or become just less effective over time. Still acceptable but loosing damping ability.
Since they are so easily to replace, if you want to refresh your ride, just get a standard set OEM and it could really tighten up your car.
Post #1038628 28th Jun 2024 12:51pm
Tractorman
Thanks guys for further info - much appreciated
Post #1038695 29th Jun 2024 9:01am
Chicken Drumstick
Do you know which bush specifically? If it is just the bottom of the shock to the axle. Then failing a car for that is pretty harsh. I’d suggest a new MoT station next time too. Chances are the rubber was only slightly cracked. If there was movement you’d have been hearing a clonk when driving. And even then simply doing the nut up a bit more would probably solve it.
The front upper bush they wouldn’t be able to see and I’d be amazed the upper rear bush had failed. Although again you’d probably hear and feel it if it had.
Post #1038698 29th Jun 2024 9:34am
Disneysland
United Kingdom 2009 Defender 90 Puma 2.4 HT Stornoway Grey
I am just replacing the rear shocks & bushes on my 90 puma with Genuine, but can’t find the correct order & orientation of the bottom bushes and washer(s). JLR parts say that there is no washer between the bushes and shock, just one washer between bushes and nut.
I have searched, this forum and others, and I’m now more confused than ever. There are no clear pictures that I can find, and Haynes is a total waste of time.
Thx
Post #1076078 24th Sep 2025 3:47pm
Mr.Jimbo
United Kingdom 2003 Defender 110 Td5 CSW Java Black
You should have cups on the axle so that removes 2 of a potential 4 washers from the arrangement (earlier cars), I think (and the way I installed my bilsteins recently) is from top down:
Damper - Washer - Bush - Axle Cup 1 - Axle cup 2 - Bush - Washer - Nut
Edit: it's also important to have the washer convex face pointing towards the bush, so as not to limit flex under articulation.
 2003 TD5 110 CSW
Instagram: e12_hue
Post #1076145 25th Sep 2025 8:34am
Disneysland
Thank you for the reply Jim. It’s not however what JLR say, or my nearest parts specialist. Here’s what JLR say, and the specialist! It’s hard to know which way the bushes go for certain but I think wide end into the axle cups.
Post #1076188 25th Sep 2025 7:34pm
Mo Murphy
I agree with mr.Jimbo.
50 Shades of Pennine Grey
Post #1076194 25th Sep 2025 8:20pm
Disneysland
Thank you for the replies. A local dealer has a very low mileage heritage 90 in stock, so I had a look at theirs. It appears that Land Rover parts are wrong! There is a top washer. Here’s the pics of the heritage one, and mine on its dolly. I haven’t tightened up the bolts yet.
Post #1076234 26th Sep 2025 3:31pm
Screbble
Yours looks spanking Disneysland.
You just need to chisel off those spot-welded cups and you’ll be right Very Happy
Post #1076238 26th Sep 2025 4:31pm
jst
I am more impressed by a radiator in the wksp Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1076270 26th Sep 2025 9:26pm
Retroanaconda
Parts catalogues have always been indicative at best, they are not assembly diagrams.
Chiseling off the cups is not necessary if using standard shocks and bushes as appears to be the case here.
Post #1076400 28th Sep 2025 12:54pm
Page 2 of 2 <12
