Home > Puma (Tdci) > 110 Rear door sticking when towing a trailer
Andyslandytd5
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
Hey Guys, I was towing a Ifor William HB505 horse box around yesterday. It was mostly unladen except for some grass mats I was recovering from the the Missus Field.
I noticed that the rear door had become stiff and the door was catching on the latch (like the door had lowered slightly. Once I removed the trailer the door returned to normal operation.
Is this normal?, I have only had 90s before. Its a 2015 110 UXS with 60k on it. It has the genuine Landrover tow bar with drop plate and supports running to back to the chassis.
I checked and nothing is loose that I can see. I even dropped the jockey wheel with the trailer still attached and took the weight off the Landy to see what change it made and nothing changed. It was not till I dropped off the trailer that it went back to normal again 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
2004 TD5 90 XS Station Wagon - 2019-2024
2003 TD5 90 G4 LE - 2009-2010
1990 Ninety 6.2 V8 Station Wagon - 2006-2009
Post #1075900 22nd Sep 2025 11:45am
Not normal and I suggest requires diagnosing.
The only way in which I can imagine this happening is if the body is flexing and that in turn suggests the chassis is flexing. If the chassis is flexing I suspect that there is a serious flaw with the chassis.
I'd be checking the chassis very closely for rot around the rear cross-member.
Post #1075908 22nd Sep 2025 2:42pm
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
Does not sound right at all. I’ve done a lot of towing with horse boxes with various 110’s and have never encountered anything like that.
As BW suggested, I would give the chassis and body fixings a thorough inspection.
Post #1075913 22nd Sep 2025 3:48pm
Dinnu
Re: 110 Rear door sticking when towing a trailer
This is even weirder, but as stated earlier, this normally happens when chassis flexes a bit as the body has to follow. It does happen when a Defender is cross axled, as the chassis is not infinitely stiff. My 90s always did it, just enough to notice.
Do you have a spare wheel on the door? Was the ground flat? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1075925 22nd Sep 2025 6:38pm
Andyslandytd5
I backed the Landy up on some car ramps and rolled around on a creeper last night. I had a good poke around and found nothing of concern. There was some peeling paint around weld seems etc but I poked around with a screwdriver and there was only surface rust (a chassis treatment is on the cards soon).
Only thing I can think is that I don’t think I was parked on level ground so may hay have been just enough to twist the chassis.
I took a few photos of the latch from the inside of the car last night. The Blue Arrow shows the part of the door latch that was catching on the door frame part of the latch (Red Arrow, Striker?)
When shut normally the door does not rest on the door frame latch at the bottom as you can see a gap (green arrow). There is only a few millimetres gap and it was not catching here so it must have only been a small amount of movement.
I will do some more investigation when I put the trailer on again next to make sure nothing sinister is going on.
Post #1075975 23rd Sep 2025 10:26am
