![]() | Home > Maintenance & Modifications > Rubber mat |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5025 ![]() ![]() |
Machine Mart sell rubber matting - get the thicker grade if you go this route, it's still thin enough to curve over wheel boxes....listed on their website.....or stable matting if you want something thicker but it's very heavy stuff
stable matting is great and looks OEM. Easy to cut with a new stanley knife blade too. don't use an old one, it'll drag. Our local equestrian place sells it for 27 quid a sheet which is more than enough
Stable matting is good stuff, whenever I've cut them for our stables I used a Stanley knife but kept the blade lubricated with water with a bit of detergent added which makes them even easier to cut ![]() Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
There are various thicknesses, can vary in "spongeness", some are hard shiney rubber to a neoprene type foam. Some can be quite rigid and thinner, these are used to protect stable walls making them easier to wash down and comes on a roll. There is a huge selection of the things, I used to build stables and as you go round the country different customers wanted different additions to keep their precious steeds molicoddled
stanley Member Since: 18 Sep 2009 Location: Dorset /hampshire Posts: 1033 ![]() ![]() ![]() |
I used stable matting too, looks great and adds soundproofing. What I also did was use someting like this
http://www.google.co.uk/products/catalog?h...ABEPMCMAE# on the edges to make it neater |
I use the thick stuff. its knobbly on one side and has a linear pattern on the other. I used it knob side down.
Upside down then
