![]() | Home > In Car Electronics > LR factory alarm, how to deactivate internal sensors (Puma) |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6054
Unplug it
| BrunoJ Member Since: 14 Sep 2019 Location: Stavanger Posts: 82
Not sure if all factory alarms are the same. In my case locking doors with key (driver's door only) starts the alarm for doors only, deactivating motion sensors.
Not very convenient, when you are in the pop-top tent, and cannot use the remote. BTW - I was always assuming the dog inside is even better than alarm... |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21029
Tape.
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
| Ridgeway Member Since: 09 Mar 2009 Location: Lausanne Posts: 24
The sensor or the alarm ? |
Could do i suppose but thought there might be a simple way to just switch it off |
Will try that |
The sensor. Just take the wire out of the back of it. You could if you wanted put a switch on it. But just having it unplugged allows all else to work, and no side effects. |
| All times are GMT |
