![]() | Home > Td5 > Noisy engine, low on power |
DefenderCan Member Since: 25 Nov 2023 Location: Canada Posts: 8 ![]() ![]() ![]() |
I would spray, with MAF Cleaner the MAF & MAP Sensors.
Run a quality fuel additive. Exhaust manifold leak will let you lose power. |
hartleys Member Since: 15 Sep 2025 Location: Wales Posts: 2 ![]() ![]() ![]() |
Thanks for the reply.
I’ve fitted a new MAF and put and injector cleaner through. MAP sensor is clean and numbers seem ok. |
Mr.Jimbo Member Since: 20 Jun 2024 Location: Rugby UK Posts: 21 ![]() ![]() ![]() |
If there is an audible ticking noise I expect you're not achieving correct levels of boost - Looking at the data (and assuming that's absolute, not gauge) I would say you're about 4-600kpa down on boost (I can't remember what the standard boost threshold is but from memory around 140-150kPa) and I suspect yours is around 8-900kPa
I'm making that assumption on the basis that 180-190kPa would be well into ECU limitations pulling fuelling to control, have you double checked the wastegate rod is moving correctly? If you're really seeing 180-190, could be a sign the wastegate is sticking closed On mine, cyl 5 had notable soot leakage evident on the gasket. Worth checking the studs into the cyl head as well. |
