Home > Faults & Fixes (L663) > Headlight again but weird issue.
Tuk1117
Hi all. Just noticed my drivers side Halo has stopped working but the weird thing is the 2 squares will light for 2-3 seconds and then turn off. Indicator will still work. I though i could have changed the halo circuit board/ module but i take it that wont fix the 2 squares not staying lit problem?
Not under LR warranty
Post #1075531 16th Sep 2025 6:53pm
Defendit..
Netherlands
Welcome, but more detailed info please. No Mud flaps for my 90.!
P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #1075534 16th Sep 2025 7:06pm
Tuk1117
The drivers side headlight circle halo has stopped working.
The 2 little headlight square lights to the right side of the light will light up for 2-3 seconds and then turn off again.
Everytime i turn the headlights on the same thing happens, no circle halo but the 2 little square lights will power on for 2-3 seconds and then off again. Not sure what else i can add.
Post #1075539 16th Sep 2025 7:33pm
Gareth
Yes both my failures were exactly the same. First time LR helped with a contribution, but second time they wouldn’t. I found a place in Manchester who repaired it for £300. Maybe you could send your headlamp to them?
https://kgautoelectronics.com/service11.html 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #1075568 16th Sep 2025 11:16pm
