Home > Td5 > air in fuel??
72formula400
United Kingdom 1999 Defender 90 Td5 HT Coniston Green
air in fuel??
hi new here..
Got a 99 td5 90
About a year ago after a bit of green laning it started cutting out after a few miles(pump starts making noise then cuts out)
Will start after turning over loads or with a tow start
Cured it by getting new coopers fuel filter and tightening up unions on housing (which is about a year old)
About a year later After sitting around for a month its doing it again...change filter ..removed air bleed valve etc but still doing it
Injectors were rebuilt 2 years ago ..new loom 6 months ago..regulator 10 years old but no leaks.
Guess new pump next?
The thing is when driving its never been faster and responsive in the 17 years ive had it.
Post #1075380 14th Sep 2025 2:55pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Have you checked for oil in the ECU? Also when did you change the injector seals?? 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1075402 14th Sep 2025 6:56pm
