Home > Td5 > Explain Nanocom readings.
landy andy
Is this normal?
Why is bonnet low?
Factory mode, is what?
Should my Td5 be “Learnt”?
MIL light “high” good / bad?
Why MIL fault?
What is passenger sill?
Why is it LOW?
Post #1075313 13th Sep 2025 11:03am
bankz5152
First of all. If you dont know what your doing. Do not play, youll ruin your car, dont mean to come across as rude but ive seen it many times. Becomes very difficult to then fix.
High / Low means active/not active.
Open and close your doors and youll see the values change, same for the bonnet. The refer to your door switches.
Mil status is to turn the engine management light on and off. Regardless of a fault appearing. Obs not ideal to turn it off.
Post #1075314 13th Sep 2025 1:13pm
landy andy
Thanks.
I’m not playing but just trying to understand. And to me, they don’t make it simple. It would be good to get an idea of what is ok/normal so if something alters or has a problem I know what it should/was before.
So you think
my bonnet switch isn’t working
My MIL is working
My passenger door switch isn’t working
Post #1075320 13th Sep 2025 3:45pm
bankz5152
Ok good Smile
To test your switches, have the nano open on that page and push the switches in and out. If it doesnt change switch is broken. If it does. It works.
Tbf apart from really indepth fault finding then the live data and fault code pages are your best bet!
Its not straight forward, could be easier i suspect its down to programming limitations
Post #1075321 13th Sep 2025 4:10pm
