Home > Maintenance & Modifications > Intercooler - Worth the cost ?
thomson_adam
Hello ,
I am looking at getting my 2.2 remapped. I am currently torn between the BAS remap which is the 170bhp or going to Alive and getting the stage two with an intercooler ? what is peoples thoughts ?
Post #1075090 9th Sep 2025 9:53am
Ianh
It’s dependent on the current and proposed use of your vehicle. If it’s going to be pushed harder, I.e heavily laden, towing a heavy trailer, lots of high inclines, run in hot climate, run at motorway speeds for a long time, over landing or a combination of some of these then a larger quantity high flow intercooler would be recommended.
Note Talking to BAS will help as Pete has answered this question to several members, noting sometimes he advises an intercooler is not required.
A good point to note is that the standard LR intercooler does fail at the crimped seams, so putting extra boost through it will put more strain on the Intercooler and exacerbate the likelihood of failure. So this should be taken account in your decision.
Lastly, BAS have also designed and manufactured a high flow intercooler. I have one and believe it is the best performing and most robust intercooler you can get for a Puma.
If BAS has any in stock I would go for that , their 3 silicon hoses and their remap inc the mapping tool ( Gap IDTool ) with diagnostics.
Ps. One thing to note , If you are looking to have a map then you really need to sort out the atrocious air intake pipework from the wing to the airbox. It is very poor and highly restrictive.
I replaced mine with a much larger round hose and this in conjunction with a BAS intercooler, silicon hoses and nuggetstuff deluxe airbox gives me all the performance I need for my 2.2 110 XS station wagon without the need for a remap. Noting Where I live is pretty flat and I don’t regularly tow heavy loads.
Post #1075097 9th Sep 2025 11:19am
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
I would say regardless of whether you go for a remap, ditch the standard land rover intercooler.
My 110 is only running a standard map, but has split two standard intercoolers in exactly the same spot.
 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #1075244 11th Sep 2025 4:20pm
Ianh
Thanks for the picture Rosco, that’s exactly where mine split as well
Post #1075250 11th Sep 2025 6:41pm
Shafski
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
And me!
Ordered the Airtech, BAS have supply issues and that’s what Pete at BAS recommended as the alternative. If you search online you can find a discount code (10%) too. IanH, Airtech are also in Essex so you could save the £20 delivery!
Fingers crossed postie delivers mine today Rolling with laughter Shafski
_________________________________________
2015 110 Montalcino Red Utility "Harriet" along with Puma on I.C.E
Post #1075259 12th Sep 2025 5:59am
Ianh
Thanks Shafski, I was fortunate that when mine split BAS still had stock so I purchased and fitted one of his intercoolers.
It’s very Handy for others to know that Airtech is another alternative intercooler supplier , and that BAS recommends them . https://www.airtecmotorsport.com/product/a...-2-2-tdci/
Post #1075266 12th Sep 2025 11:33am
