![]() | Home > Tdi > Camshaft gear out by a tooth |
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 231 ![]() ![]() ![]() |
Looking for some second opinions on the below whilst i'm doing the timing belt on my 2006 300Tdi. Not done it on this vehicle before. It has 112k miles and don't know when it was changed previously, but definitely has been.
The camshaft gear was 1 tooth out on the old belt. I locked the crank and FIP before the belt came off, and the FIP plate was loosened. The vehicle has been running fine and not overly smokey exhaust. It passed an MOT recently. No power issues. I'm wondering if the belt has jumped a tooth, or someone changed it in the dark, or worst case - the camshaft gear alignment has been changed relative to TDC. Don't want to smash the engine on first start.... ![]() ![]() Click image to enlarge The oil pump flats look fairly worn. What do you think? ![]() Click image to enlarge LR Workshop New parts illustrations https://www.lrworkshop.com/diagrams/land-r...ed-corners Find a Defender's history and spec: https://defender.lrworkshop.com |
Thanks Fossil.
I had turned it over and no interference. I'd read about a single tooth being close to the tolerance between valves and pistons. I also read it'd be fine ![]() I did the valve clearances also to double check and they were all 0.5-0.7mm, so pretty loose. So all back together now, timed up correctly and it runs fine. I can't say I notice a difference in performance or smoke (i.e not much), but time well tell if there's an impact on MPG. It must have been a quick job previously - as you say it's hard to see without the radiator out. The crank pulley bolt wasn't that tight and I also found a bolt missing from the front cover. The belt was unbranded and the tensioner/idler, when spun, sounded like they had been on since new. Also managed to change the coolant, flush the intercooler and wash the mud out of the radiator and condenser fins. LR Workshop New parts illustrations https://www.lrworkshop.com/diagrams/land-r...ed-corners Find a Defender's history and spec: https://defender.lrworkshop.com |
