Home > Puma (Tdci) > Puma starter
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
Puma starter
Had my starter giving up on me last Friday. (solenoid ok, motor not turning) Of course just after being loaded with hay and still standing on the weigh bridge at the farm. Rolling Eyes Yes of course there were 2 trucks waiting to get their weight taken.
FYI the starter is the same as the ford transits, Fiat Ducato Peugeot Boxer and Citroen something with the 2.2 or 2.4 TDCI / HDI engines.
Multiple reference numbers but the RUD500270 seams to be the one known to all.
Prices vary from china brand new 62 euro to a very nice 530 euro for an original ford. (after that I was too afraid asking Landrover)
Googled some repas video’s and sites to see what repas really means. Parts for the starter can be found, OEM is BOSCH with LR logo.
Took the starter out (If you thought removing the EGR was tight then try this, just for fun)
Thing worked without problem on my workbench.
So back to the net searching a bit more. Clutch dust issues are common on the transits but these have a DMF causing this. No fear, open the thing and look.
Full of dust...
Now,for some ranting: the alternator has an open vent hole in its body, just as the vans. Thanks for the clever thinking landrover. Then the snorkel equipped '90 corolla starter I saw in one of the video’s looks posh doesn’t it?
So people take care with wading and power washing in that area.
Anyway, cleaned the interior (nothing fancy and not much you can do wrong) of motor and solenoid with brush, air and liberate amounts of wd40 and then brake cleaner as wel as a finishing spray of contact cleaner.
All back together and test wired the starter ran much quiter and at a higher speed.
What to risk? Put it back in and now 100+ starts further it still works.
I don’t like the fact I couldn’t pinpoint a mistake (besides the dust) but it's working again.
Smile
Post #189584 29th Nov 2012 8:04pm
ickle
Thanks for that Tatra, not grovelled and looked specifically at the starter motor but would it be possible to 'clean' in place??
On a couple of occasions recently when its been cold, I've tried to start mine without waiting for the glow plugs (200tdi style) and it gives every symptom of a flat battery.
So, is the starter heading west?
Or do the glow plugs take such a huge current that there's not enough juice left for the starter?
Or do I have a suspect earth??
Cheers Keith
Post #189586 29th Nov 2012 8:25pm
tatra805
Ickle,
Broken starters can be 2 things when turning the key:
- nothing, no sound: solenoid broken
- clear single click but no movement: solenoid ok, motor broken or stuck
When your starter is turning but slowly I would indeed look into connections and earth and solenoid.
Why? If it is only a low battery you’ll get multiple clicks from the solenoid a tak-tak-tak sound as battery is not able to deliver enough power.
Cleaning without taking it out is not possible. You have to dismantle the starter assembly to get inside. (search youtube, a lot of video’s showing the procedure how to dismantle)
Regarding connections and wires / earth.
Measure on the big wire that comes to the starter from the battery and the starter body how many volts you have. This should be the same as what you measure between battery plus and minus. If there is a difference (say bigger than 0.5V) you are looking at connections or bad earth.
Then measure voltage between the 2 big nuts on the starter when starting, this should be minimal, if bigger than 1V your solenoid contacts are worn out and you’ll need a new solenoid. (separately available from bosch)
Best all be done with starter in a vice as on a puma you’ll need small hands and good eyes to get to the starter with the test leads.
Procedure to remove the starter in the workshop manual is spot on but I also had to remove the bolt/clamp holding the main + cable to the chassis to be able to take out the starter.
So I would
- disconnect battery
from top:
- remove big nut on starter (nr13 + u-joint + 2 long extensions and ratchet)
- remove small nut on starter (nr10 + u-joint + 2 long extensions and ratchet)
then from underneath the car
- remove main +wire clamp (nr 15 bottom, 17 top)
- remove fuel line bracket from top stater stud (nr 10 small ratchet + extension and portion of swearing)
- remove both studs (nr 13 small ratchet)
- wiggle out starter
I'm suspecting earth or solenoid contacts from your description. Glowplug current is much lower than what the starter needs. (starter engine is taking +- 55 amps to run without load freespinning in a vice and 350 amps to turn around a hot engine ! if i remember correctly preheating is taking somewhere around 30 amps.
Keep us posted!
Thumbs Up
Post #189698 29th Nov 2012 11:55pm
ickle
Hi Tatra,
Last weekend I finally thought I better look at my starter motor. I found it easier to disconnect / remove turbo hoses and some coolant hoses (replaced antifreeze whilst I was at it) to gain access - very tight on a left hand drive with air con!
On strip down, the brushes were starting to break up, just worn out I suppose (131000km) , but very little dirt and rubbish in there. Quickest / easiest was a replacement from local motor factors £100 inc Vat and it now spins over very quickly regardless of pre heat.
Thanks again
Keith
Post #265396 10th Sep 2013 10:10pm
Skimech
England 2007 Defender 90 Puma 2.4 XS CSW Corris Grey
Good evening. I have a similar issue. Been scrolling for a solution. So my 2.4 puma will start after 3-4 separate turns of the key. The first 3 attempts it is like the battery is flat and tries to start. On the 4th attempt it fires into action no problem. If I then do a short journey and turn off the ignition it will struggle to start again.
It is worse when the temp drops or in wet weather.
Do you think this is a starter Motor issue? Battery seems to be ok.
Cheers.
Andy.
Post #1074691 3rd Sep 2025 9:42pm
ickle
Talking to a friend, the geared starters used on the Puma and many TDCI fords don't last overly long.
I would try firstly to check and clean all the earths and battery connections are clean and tight.
Possibly could be the actual contacts in the ignition barrel - easier (fiddly) and cheaper than the starter
Then the starter!
Post #1074719 4th Sep 2025 12:00pm
andy63
I would think if the starter motor is pulling in and operating even poorly its not an ignition switch issue..
Starter solenoid contacts or starter motor wiring issue..
I replaced my starter motor a year or so ago because I was on there with good access, not because the one on wasn't working..I was surprised how much faster it spun over with a new motor...not really sure why the big improvement as I didn't notice any poor connections on removing the old one....
Post #1074723 4th Sep 2025 2:07pm
