![]() | Home > Maintenance & Modifications > 110/90 steering shaft upgrade? |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 683 ![]() ![]() ![]() |
I would stick with the original one as both top and bottom joints are replaceable, unlike the Td5 / Puma type which only has one replaceable joint, the second is integrated into the shaft and requires the shaft to be replaced.
I always thought the later shaft was a downgrade! I also have my own opinion of Bolt on Bits!!! |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 594 ![]() ![]() ![]() |
Thanks for the reply, I’ve just ordered the original type. 1983 110 automatic OM606
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6217 ![]() ![]() ![]() |
Wasn't the later shaft designed with the shear pins in it, so if you had a front end smash the steering column/wheel didn't get pushed up into your face?
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2784 ![]() ![]() |
The earlier shafts have a slip joint in them to achieve the same end.
Ah ok, I couldn't remember
![]() edit: oh yeah, the big rubber thing with the dogleg shaped shafts... remember now lol |
