Home > Puma (Tdci) > Rear hub assembly MY2015 110
ojdefd
United Kingdom 2015 Defender 110 Puma 2.2 SW Montalcino Red
Hi all,
Recently undertook a overhaul of the consumable brake parts on my MY2015 Defender 110.
I damaged that the rear ABS sensor was fault and needing replacing (probably due to damage caused trying to remove a broken bolt on the stub axle to diff flange). Upon disassembling the hub to try and remove the seized ABS/ wheel speed sensor, I discovered a separate (self-inflicted) issue with the adjusting nut and spacer washer.
Somehow the spacer washer has been rotating with the wheel and carved a groove out of the stub axle threads Mad . It also seems like the hub cap was up against the hub nut maybe causing the rotation. Any ideas how this might have happened?
Note I have followed the Haynes manual to the letter with backing off the adjusting nut by 90 degrees once torqued to the required setting, then torqueing the hub nut to the 210Nm as required. There was no rocking in the brake assembly and I'm sure the bearings were seated/ positioned correctly.
I had only driven the vehicle maybe 100m to check the brakes had been bled!
Any help would be appreciated.
Many thanks.
Post #1074575 2nd Sep 2025 11:44am
Johan_B
Sweden 2007 Defender 110 Puma 2.4 CSW Tonga Green
To me it sounds as if you have mixed the procedures and also might have the old two nut system.
When you write "spacer washer", is that the washer between two nuts? Or is it a spacer behind the thrust washer? I will assume the former below.
If you have two nuts, then you should first torque the inner nut to 50Nm, then back it off 90 degrees and then torque to 10Nm. Finally you should torque the outer nut to 50Nm. Last you tab over the lock washer on both nuts.
In your description I see three mistakes: Not torquing to 10Nm after backing off. And torquing to 210Nm on the outer, which I guess can damage the threads as the nut is not so thick. And finally not tab over the nuts with the lock washer. Basically, since the inner nut is not torqued, the nuts will be free to move and the washer as well.
Post #1074577 2nd Sep 2025 12:11pm
TexasRover
Yeah make sure you did not mix up the two old or new systems. Crucially the newer system has a spacer tube fitted between the two inner bearing races and so the tightening torque of the nut is immaterial. After properly tightening you lock it in place with peening and that's it.
There is plenty discussion here about the pro's and cons of each system, but they are interchangeable but you can't really mix them
Post #1074578 2nd Sep 2025 12:50pm
Bluest
I've not looked for a while, but I think there may be parts of the haynes manual that confuses the 2 systems as well. I'm sure I recall a diagram showing the 2 nut arrangement accompanied by text describing the correct single nut system. 2007 110 TDCi Station Wagon XS
Post #1074585 2nd Sep 2025 1:54pm
ojdefd
That explains it. The Haynes manual is misleading. I have gone back to the original set up of bearings with spacer tube, tabbed washer and lock nut. Looks and feels far better.
The two nut assembly seemed too long, meaning that the drive flange clashes with the lock nut causing the nuts & washer to rotate and damage the stub axle.
Thanks for your help.
Post #1074700 4th Sep 2025 7:36am
Johan_B
I don't think there should be a difference in the build depth between the two systems. The two nut system has significantly thinner nuts than the one nut. Also, if you have a spacer and one nut, there is no tabbed washer, you stake the nut where the stub axle is flat, to prevent rotation. Could it be that you still have a mix of parts?
If you have the spacer, and the correct one, I disagree with TexasRover that the torque is immaterial. At 210Nm the spacer will be compressed slightly and set the correct pre-load. It will also effectively lock the inner races to the stub axle, preventing them to rotate.
I had all bearings replaced on the rear axle just before I bought the car, and the mechanic had not applied the correct torque, so I had to replace them again when I found there was play. Once I un-staked the nut I could remove it with my fingers. Of course I don't know what torque he applied or if this was due to races not being seated. Since TexasRover has another experience I am not saying this is inevitable, just that I would much rather torque it correctly when I do the job, then risking this to happen. That said, I have converted to the old, two nut system on all four wheels now.
Post #1074703 4th Sep 2025 8:27am
