I have missed this. No lights = no software running in ECU. You can also check this observing the main relay - with ignition on, it will click, with ignition off, it will take like 8 seconds to click. When software in ECU is not running, it will click inmediatelly after ignition off.
Possible problems - broken CPU, broken of corruped flash memory or problem between CPU and flash memory. Lot of time, it is because of broken small SMD resistor - they are not the best quality."Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
2nd Sep 2025 9:11am
Martin Site Admin
Broken SMD resistor it was, thank you so much for your help 1988 90 Td5 NAS soft top
2015 D90 XS SW
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
