Home > Puma (Tdci) > Brembo Discs + Pads For '57 Plate Puma 110 XS
pumaxs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Zambezi Silver
Sorry to be a pain, but I'm struggling to order the correct parts for my vehicle.
I've spoken to one Brembo agent who was hopeless & one that was very helpful, but as baffled as me (Tim @ Opie Oils take bow Smile ).
A response from Brembo attached this data sheet:
My VIN No. is prefixed SALLDHMS, so does not seem to relate to the various listed options - Or am I missing something?
I'm booked in for my MOT on the 22nd June & need to get the parts ordered + fitted before then.
Can anybody help? :blub:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  '57 Defender 110 XS Station Wagon 2.4tdci
Post #429154 7th Jun 2015 9:03am
Fifth Horseman
Where the vin is shown on a lot of suppliers part lists, they omit the first part of the vin (the SALLDHMS7 part).
The catalogue page shown seems badly written as for example where the 2.4TDCi is shown the chassis no. range actually predates TDCi production, (vin 7A000000 onwards)
Quick breakdown of vin number (example SALLDHMS77A123456)
SAL - Manufacturer ID
LDHMS - Vehicle attributes (LD=Defender) R/LHD body type etc.
7 - Check digit
7 - Model Year (2007)
A - Assembly plant
123456 - Sequential number.
The TDCi brakes are the same as used on the later TD5 Defenders, hence the seemingly strange vin shown on the Brembo catalogue.
Is there any reason for wanting Brembo parts particularly? TRW are an OEM who's brake parts I've had no problems with. Try contacting Steve at Advanced Factors (forum sponsor), he also gives 2 year warranty on most parts.
Post #429185 7th Jun 2015 10:55am
Martin
Site Admin
Advanced Factors do brakes for Defenders, and can/do supply Brembo.
http://www.advancedfactors.co.uk/05-brake-...-231-c.asp
The VIN bit at the end of the line on that Brembo page applies to the pads only, it is in the "info" column for pads. That's to do with the change of caliper type in ~1993.
A 110 will have the vented front discs.
Vented fronts are 09.5488.10
Rear 110/130 Td5 or Puma are 08.A841.10
90s typically have solid discs and smaller rear discs so are different part numbers.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #429193 7th Jun 2015 11:15am
pumaxs
Fifth Horseman:
Thanks for the explanation of how the Vin No. breaks down.
I should be better informed after owning Land Rovers on & off for a good many years Embarassed .
However, I don't usually hit a complete 'dead end' when searching for parts.
As to my reasoning:
Land Rover Genuine Parts, whilst being of undoubted high quality, are more than double the price of Brembo!
OEM seems to be a fairly meaningless phrase, which has been well covered elsewhere on this forum, and I would be unsure of what I was getting for my money.
I will not buy Britpart, as I had one of their indicator stalk/light switches fail inside 6 months and do not trust the quality of their parts.
Brembo parts (I've also considered Ferodo) seem to strike a good balance between price and quality.
So, that's my (possibly flawed) logic!! Smile
Martin:
Thank you for your reply.
At the risk of seeming a berk (I've only just learnt that it's a shortening of the rhyming slang "Berkeley Hunt" - You learn something new every day!! Laughing ), but being willing to take a hit for the benefit of the wider Puma owning membership, are these the other parts that I will need?
Front Pads: P 44 015.
Front Fitting Kit: A 02 257
Rear Pads: P 44 006
Rear Fitting Kit: A02 256
I may well try Advanced Factors, in the hope that they have the parts in stock, as I'll soon be running short of time to get the work done.
Thank you both again for all of your help Bow down '57 Defender 110 XS Station Wagon 2.4tdci
Post #429242 7th Jun 2015 4:20pm
Fifth Horseman
Sorry for not being clearer when I used the term OEM. TRW are one of the manufacturers whose brake components that Landrover fit. AP-Lockheed and Brembo are others.
I agree with your comments about a certain blue labeled brand - have had callipers from them where the mounting holes didn't line up with those on the axle Shocked
Post #429248 7th Jun 2015 4:34pm
pumaxs
Thanks for the info.
I also took a look in the Brakes section of the Puma Workshop Manual, and that lists the brake pad compound as being 'Ferodo 3440 Non Asbestos', so they're obviously on the OEM list as well. '57 Defender 110 XS Station Wagon 2.4tdci
Post #429258 7th Jun 2015 4:49pm
Martin
Site Admin
Rear Pads: P 44 006
The front pad is P 44 005 (P 44 015 is 1mm thinner with no application data)
Front fitting kit: correct
Rear pads: correct
Rear fitting kit: correct
Advanced Factors generally do have everything in stock Thumbs Up
They have a front 110/130 Brembo kit: http://www.advancedfactors.co.uk/008bre-la...5163-p.asp
And rear 110/130 Brembo kit: http://www.advancedfactors.co.uk/009bre-br...5351-p.asp  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #429279 7th Jun 2015 6:25pm
pumaxs
All in stock & ordered from Advanced Factors.
Thanks again for all of your help. '57 Defender 110 XS Station Wagon 2.4tdci
Post #429504 8th Jun 2015 2:45pm
Fifth Horseman wrote:
7 - Check digit
I think that digit actually refers to the transmission and steering - 7 being RHD 6 speed manual transmission.
From SALLDHMS you get:
SAL = World Identifier = Land Rover (UK)
LD = Vehicle Type = Defender
H = Class = 110 inch
M = Body Style = 5 door station wagon
S = Engine = 2.4L Euro spec (EU4)
Post #429691 9th Jun 2015 9:26am
pumaxs
All items delivered just after 9.00am this morning.
Great service. Very Happy '57 Defender 110 XS Station Wagon 2.4tdci
Post #429699 9th Jun 2015 10:40am
Martin
Site Admin
7 - Check digit
Indeed, there is no check digit on a non-North American/Chinese VIN.
http://disco3.co.uk/wiki/Vehicle_Identification_Number  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #429709 9th Jun 2015 11:10am
Fifth Horseman
My mistake Embarassed
For info I think the following are correct but may not be a complete listing:
Character 6 - Class:
A=90 inch
H=110 inch
K=130 inch
Character 7 - Body Style:
A=Regular (Pick-up, Hard Top or Canvas)
B=3 Door Station Wagon
F=4 Door crew cab - non hi-cap
H=Hi-cap
M=5 Door Station Wagon
Character 8 - Engine
S=2.4 TDCi
Character 9 - Gearbox type and Drive
7=RHD
8=LHD
Post #429750 9th Jun 2015 3:43pm
pumaxs
A perfectly timed 'How To' article in the latest edition of LRO magazine covers the replacement of front pads & rear discs + pads on an ABS braked 110 SW!!
In this article, they also seem to recommend fitting new anti-squeal shims, rear hub nuts + rear caliper securing bolts.
None of these items are part of the 'disc + pad kit' bought from advanced factors.
Should I be buying them as essential items before starting work?
Also, my sphincters starting to twitch re: removal of the ABS rings, as they look fragile + expensive.
Am i right to be worried? Confused '57 Defender 110 XS Station Wagon 2.4tdci
Post #430167 11th Jun 2015 9:19am
pumaxs
New hub nuts + calliper bolts used.
All fitted by local garage with no issues to date. Very Happy '57 Defender 110 XS Station Wagon 2.4tdci
Post #432480 21st Jun 2015 12:25am
Liam Murphy
United Kingdom 2009 Defender 110 2.5 TD HT Tamar Blue
Rear Pads: P 44 006
Rear pads: correct
Anyone know why there's a 1mm difference between P 44 005 and P 44 015? I need front brake pads pretty fast for a 2009 110 Utility with vented front discs. A local parts supplier has the P 44 015 in stock for collection in the morning, but typically out of stock for the P 44 005 that Martin suggested above.
Post #1074460 31st Aug 2025 8:07pm
