Home > Td5 > Swivel Pin Shim Advice
IronKettle
United Kingdom 2000 Defender 110 Td5 CSW Alveston Red
Rebuilding my swivel hubs as the bearings finally gave out. Castor corrected ones are going on (as the previous owner had them in the truck when I bought it!).
I'm at the stage where I'm setting the preload on the bench, but the number of shims required seems insane. With no shims and doing the bolts up hand tight to give a little bit of resistance, there is a gap of 2-3mm.
Is this normal? Even using the largest shims I'd need a fair few! I've only got a few on hand at the moment.
Thanks in advance!
Post #1074301 29th Aug 2025 10:58am
landy andy
No. That doesn’t look correct to me.
Post #1074302 29th Aug 2025 11:27am
Are the outer bearing races pressed firmly against the seats in the ball? If so, I suggest measuring the seat-to-seat dimension of the original and castor-corrected balls in case the castor-corrected one is out-of-spec.
Post #1074309 29th Aug 2025 11:51am
IronKettle
Yep, bearing outers are fully tapped in!
I'll tap the top one out again and measure vs original (or whatever was on the truck before...).
Post #1074310 29th Aug 2025 11:55am
bankz5152
A little odd but not unheard of.
Afaik you cant set preload in the bench, all needs to be assembled and set by feel or a newton meter (baggage/fishing scales can work)
Is the bearing sat flat in the race? Ive made that mistake before. Fitted it slightly off center and crushed it.
Post #1074322 29th Aug 2025 3:46pm
IronKettle
From my reading & watching videos you should be able to set it on the bench with some hanging scales.
I dug out 2 of the thickest shims (which isn't far off what was on the existing swivel) and that seems to fill the space & set the preload pretty close (haven't faffed with thinner shims yet, was just playing around with it on lunch).[/quote]
Post #1074324 29th Aug 2025 4:24pm
There's no reason at all why you can't set the preload on the bench.
Post #1074326 29th Aug 2025 4:47pm
bankz5152
Thats me schooled!
Always done the job on car with everything attached.
Post #1074327 29th Aug 2025 5:10pm
Oldowner
I have had this before with combination of replacement aftermarket swivel balls and aftermarket pins; I’ve always figured that aftermarket manufacturers have erred on the side of caution and and added a little bit to the swivel and shim measurements so as to avoid having the situation where the preload is incorrect without any shims
It important to use the correct bolts, those look like incorrect stainless steel ones, which is fine for initial shimming but after the correct shim stack has been obtained they should be swapped to new genuine high tensile bolts for final assembly.
Preload can be set on bench as long as rear seal and retainer are fitted to housing as this provides the resistance that you have to overcome. I used to have a bracket I clamped in a vice to bolt the swivel to when I did lots of them.
Post #1074336 29th Aug 2025 10:30pm
The swivel preload should be set without the ball seal fitted.
Post #1074339 29th Aug 2025 11:06pm
Oldowner
Correct! Its a long time since I’ve done one!
Post #1074342 29th Aug 2025 11:55pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Its quite possible you have the bearing reversed. Verify you don‘t have the upper in the lower and vice versa.
Good luck. 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1074378 30th Aug 2025 5:20pm
IronKettle
Do I really need the high tensile bolts over stainless? The bolts shouldn't take much stress as the pin fills the entire housing, any axial load should be placed on the pin I'd have thought...
Good luck.
Bearings are the same top and bottom.
Post #1074448 31st Aug 2025 6:29pm
All the weight on the corner of the vehicle is trying to push the top pin out, so there is a fair load (which will be increased by the radial load on the taper bearing pushing in the same way).
Perhaps a more relevant question is what possible reason could there be for using stainless fasteners there (or almost anywhere else for that matter)? I cannot think of a single advantage or justification myself.
Post #1074452 31st Aug 2025 6:43pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Sorry blackwolf, think you might be wrong on this? All the weight on that corner is resting on the bottom bearing of the swivel. The top swivel pin bolts only contain the preload.
Post #1075293 12th Sep 2025 9:17pm
