![]() | Home > Maintenance & Modifications > Door Switches - Classic Defender |
| donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1909
That looks really good. The ‘boss’ has mentioned an ultrasonic cleaner recently - maybe I should cave in (and drag my interior light switches off the back shelf where I abandoned them about 10 years ago!
Since then, when I want light I switch something on. Is the cleaner anything special, or just one of those wee jewellery cleaning jobs? Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
| 300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 852
Nothing at all special, it is a cheapy 600ml capacity Amazon special with some Sea clean2 metal jewellery cleaner which is said to remove "tarnish, rust and carbon" the only warning is not to use it on plated metals but I thought the copper would be OK.
I went in to the whole endeavour with the view that as it didn't work before I had nothing to lose and potentially £15 to put to something else instead of new switches. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
I should also say that it has done a better job than the toothbrush and contact cleaner that I did during Covid Boredom. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Thanks Phil - worth knowing.
