Home > Wheels & Tyres > 18" wheels
90def
2011 Defender 90 Puma 2.4 HT Epsom Green
18" wheels
Can you put 18" wheels stright on a 90 puma with no mods cheers phil
Post #609605 15th Mar 2017 1:03pm
You can certainly buy 18 inch wheels that will fit on the hubs, but the question of whether any mods are needed will depend in the tyre size that you want to fit. Darren
Post #609606 15th Mar 2017 1:16pm
JOW240725
Assuming they are Defender wheels and the chosen tyre gives a similar circumference i.e. 265/65R18, then should be any issues Thumbs Up James
Instagram @suffolk_rovers
Post #609608 15th Mar 2017 1:26pm
90def
18" wheels
Was going to put 265 x65 18 only to fill the wheel arch out cheers Phil
Post #609612 15th Mar 2017 1:35pm
90def
18" wheels
Will these affect the fuel consumption
Post #609620 15th Mar 2017 1:59pm
They are essentially the same diameter as standard tyres, so should fit without issue. Depending on what you've currently got fitted, you may need to tweak the steering stops, but 265 is a standard width so it won't be much.
Whether they'll affect fuel consumption again depends on what you're comparing it with, as well as the tread pattern you choose. If you're going from a 7.50 road biased radial to mud terrrains then it might have an impact. In practice though, it probably won't make much difference. Darren
Post #609624 15th Mar 2017 2:08pm
JOW240725
From reading only, the effect on mpg will be very marginal. 18" wheels may give it a slightly harder ride, as less tyre to absorb bumps and stiffer, but handling/roll should improve. You also need to consider it's not just the wheels that are more expensive, the tyres are more for less tyre, for example BFG KO2 265x65R18 tyres are about £163.86 incl. VAT compared to 265x75R16 at £134.95 incl. VAT, adds about 20%.
You may just need to adjust your steering stops, but that's not difficult. Thumbs Up
Glad you're keeping the Defender though! Thumbs Up James
Post #609627 15th Mar 2017 2:12pm
90def
18" wheels
I've had it from New .was looking at a isuzu pickup for some insain reason I think I will spend the money on mods for defender .it spends most of the time of road with my job game keeper wheels and some new seats and it's all sorted
Post #609633 15th Mar 2017 2:43pm
bankz5152
Any reason why? They look hideous on Defenders as the tiny discs and callipers can't fill out the alloy properly, just looks off.
If you want to fill the archs get some 265/75 or 285/75 tyres.
Post #609650 15th Mar 2017 4:36pm
JAY BOY
Wales
I have 18" on mine it make a world of differance to the drive.
265.65.18
Post #609717 15th Mar 2017 10:18pm
chris d3
England 2011 Defender 110 Puma 2.2 USW Stornoway Grey
I've got mine on 285/60/18
And had it on 275/65/18
Post #612906 28th Mar 2017 7:59pm
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
285/60R18 Cool
Post #612913 28th Mar 2017 8:09pm
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
I have 275 70 18 on mine Thumbs Up but thats a 33" tyre 2004 TD5 Defender 90 xs station wagon
Post #613157 29th Mar 2017 10:02pm
holoduke
Netherlands 2011 Defender 110 Puma 2.4 CSW Stornoway Grey
Late post. But can you tell me the rim brand/type you have there? I would like to have the same setup.
Did you modify anything?
Post #1074028 25th Aug 2025 9:04am
chris d3
Twisted 18 et0
I put them on my trailer as well
Post #1074331 29th Aug 2025 6:53pm
