![]() | Home > My Defender > Welshsurferdude could be back! (AGAIN!) |
| Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2531
After 11 months and 30k miles most of it towing at max weight all over the county and generally being worked hard.
it has finally made it into the workshop for its first service after finding some spare space/time as ive been on holiday! We have discovered the exhaust is barely hanging on rear drive shafts have worn track rod ends are worn so plan is to do a major service, new one piece rear half shafts, new TRE's, my mechanic will do a custom stainless steel exhaust and also do the air intake pipe and air box in stainless/ally should go a lot better after these mods and new bits! Next step is to fit my new ORD winch bumper and see if I like it then add some LED aux lights for winter. Click image to enlarge 2011 Santorini Black USW XS. 2015 Discovery 4.5 Black pack Firenze red XS |
Managed to find time to fit a ORD winch bumper from Belgium
Warn Winch Zeon looks great in this bumper but I will have to cut the air con grille surround to fit it unfortunately. I will run the wiring to the battery box tomorrow and bolt the winch to bumper securely. next job is to find some Aux LED lights I fancy to go with this front end. Any suggestions? Click image to enlarge 2011 Santorini Black USW XS. 2015 Discovery 4.5 Black pack Firenze red XS |
| All times are GMT |
