![]() | Home > Modifications & Maintenance (L663) > Retrofit / Upgrade Domestic Plug Socket |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3496 ![]() ![]() |
That's some fine work you've done there, and all invisible.
Great use of the under floor storage area for the inverter. |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1472 ![]() ![]() |
That’s a nice set up. Also neat idea for the compressor.
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 473 ![]() ![]() |
Thx @lightning & @Moo
Thread about the compressor and airtank can be found here: https://www.defender2.net/forum/topic80080.html No Mud flaps for my 90.! ----------------------------------------- P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3415 ![]() ![]() |
Have you done anything to your battery / charging set up or will you only run the invertor with the engine running?
For now I'am running the Inverter only shortly for coffee or my electrical inflatable matrass.
I have to find out in the morning if there is some juice left after a night of running the ARB fridge. So maybe the Inverter needs a short startup and idle for powering the Nespresso coffeemaker Planning is second battery in the future but that is expensive with all the charging and control devices needed. No Mud flaps for my 90.! ----------------------------------------- P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
I suspect running the fridge all night of your main battery will definitely flatten your battery.
The_75th Member Since: 28 Apr 2023 Location: Devon Posts: 35 ![]() ![]() |
I assume your car is not a hybrid? If it were, I'd be worried about the load on the DC:DC charger that is already showing to be a weak component.
I'd be interested in replacing the actual inverter with a higher capacity one. I've yet to find any actual details on the inverter LR have fitted and whether there are higher cap versions of it out there. |
I wouldn't worry about DC/DC , this is connected directly to your main battery. Nothing else involved.
For a higher watt pure sinus inverter you'll need much heavier cables, so upgrading the 180w is not possible. Mine is working fine, not one problem since installing. In case you suspect your main battery is a little low, you just let the engine Idle. ( Not a hybrid, see my signature ) No Mud flaps for my 90.! ----------------------------------------- P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
