Home > Maintenance & Modifications > Starting Issue
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Starting Issue
Over the last few months 1st morning start up gremlins have crept in. Some mornings it's fine, other the starter spins the engine for 15 seconds or more. Happens on hot days as well as colder mornings. For the rest of the day she starts in the button.
No splits in any pipes etc.
I've run a bottle of Revive through her to remove any carbon build up as well as Wynns injector cleaner and that has improved engine performance (Higher MPH from same RPM).
I had fault code P0220 come up the other day but then having cleared codes its not reappeared.
I'm thinking it may be the Potentiometer and Pedal Assembly - LR030043 thats causing the issues.
Any ideas appreciated.
Post #1073537 17th Aug 2025 2:15pm
