Home > General & Technical (L663) > Activating ACC, ATPC, TR2 Auto, Park Assist, wheel size etc
Page 11 of 11 <123 ... 91011
SJHowi
United Kingdom 2016 Defender 90 2.5 Petrol Works V8 Auto Corris Grey
tooth_dr wrote:
I’ve just installed ACC on the car, but notice now my wing mirrors aren’t folding on locking. Does that mean it hasn’t worked properly or something else?
same , did you sort this?
Post #1027272 8th Mar 2024 12:50pm
defending
Anyone managed to fix the park assist grey out start button issue ?
Post #1040200 17th Jul 2024 11:43pm
JonathanP
United Kingdom 1998 Defender 90 300 Tdi SW Caledonian Blue
I have the same problem re the park assist greyed out start button issue,. The system will look for a parking place, miss quite a few, the Start button does not work, and I can not switch it off?
Post #1040218 18th Jul 2024 10:31am
alamri666
United Arab Emirates
DefenderMidlands wrote:
After changing CCF files or updating scripts to clear brake error YOU HAVE TO go to Main menu, select DADC module from drop down list, then click on CCF memory and select 'DADC-DriverAssistanceDomainController Learn vehicle configuration (as in the picture) and do the same with the IGM module relearn both of them (picture shown below)
After check DTC, clear DTC on both modules, lock car and leave to sleep for 10 minutes and it will work (this info is from GARY at autosvs)
I have used this software before; yes, after any change, it is recommended that you follow these steps.
Post #1043634 23rd Aug 2024 11:36am
copysat
You've been so helpfull
Post #1045285 9th Sep 2024 9:57am
copysat
You have knowledge and experience, and I would like to benefit from them. Please get in touch with me (PM)
Post #1045289 9th Sep 2024 10:12am
Tyrer1985
Hi I have added dynamic mode and can select on the touchscreen but if turn the toggle to move through the modes it will not select dynamic mode it stops at eco. Is this normal? Thank in advance
Post #1072950 7th Aug 2025 3:59pm
Bobbobbobbob
No mine doesn't do that. Can use either method. I know this because it took me a while to realise I could use the touchscreen!
Post #1072977 8th Aug 2025 7:18am
Tyrer1985
Did you use the options listed on this post to activate dynamic mode? Anything else needed after the ccf change? I don’t get the red dials either.
Post #1073033 9th Aug 2025 12:03am
Bobbobbobbob
I kept a note from the changes. Listed below.
Probably worth checking that all the settings actually changed.
Also, I'm sure I've read on here the red dials don't work for everyone.
Dynamic Mode
EUCD-129 Terrain Response Fitment, Set to "Auto Terrain Response Dynamic & Configurable Dynamic Mode"
EUCD-245 Dynamic-I
Standard: Dynamic-i Not Fitted
Changed to: Dynamic-i Content with Configurable Dynamic Mode Screen
MultiCAN-562 DynamicProgMode
Standard: Not available for selection
Changed to: Available for selection without timeout
Other possible value: Available for selection with timeout
MultiCAN-605 ConfigDynamicMode
Standard: Not Fitted
Changed to: Fitted
MultiCAN-777 Ter Dyn Select In FCPB
Standard: Control interface not available in FCPB
Changed to: Rotary used for selection within touch screen
Post #1073034 9th Aug 2025 6:06am
