![]() | Home > Td5 > Td5 oil pressure on start up |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 999 ![]() ![]() ![]() |
I would suspect your oil pressure switch (sensor) might be failing. NUC10003
Good luck 2020 range Rover Mk IV Autobiography PHEV 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 689 ![]() ![]() ![]() |
Are you sure, you have no fuel in oil leak? Thin oil diluted by fuel can make this problems.
If you hear some noise when the oil light is on, you have probably low oil pressure, not broken oil pressure switch. To be sure, you have to remove the pressure switch and measure the oil pressure with a gauge connected instead of this switch. What oiĺ do you use? TD5 has oil presurre "regulator" in engine. I have seen one engine with tiny metal particle blocking the regulator, preventing oil pressure to rise to the righ value. Also TD5 oil pump is "powered" through small chain, and it was common, that the chain wheel get loose on the pump, because of not tight (no loctite from factory) screw holding it (lot of engines died because of it). "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo ![]() |
